Question about Philips 9P5034C 50" Rear Projection Television
Cloudy picture cant adjust color ,picture to dark
  • 822 Answers
Check CRT socket and crt board.
Posted on Jun 03, 2009
  • 3 Answers
Have cloudy, hazy picture
SOURCE:
How do i get the night vision picture to come in better on the moniter
INSTALL A EXTERNALL ILLUMINATOR IN VIEW AREA IT HAS IT'S OWN POWER SUPPLY , AND NEED NOT BE NEAR CAMMERA ONLY IN IT'S VIEW AREA THIS WILL INCREASE BRIGHTNESS OF VIDEO IN DARKNESS
Jun 24, 2014 | Lorex 4 Channel Home Surveillance System
Picture cloudy hazy
based on model number it could be cleaning or another issue--with color turned off what color is the screen? On this set with back removed also clean the 3 large lens as if dusty picture will be dull and somewhat dark.
May 03, 2012 | Philips 60PP9202 60" Rear Projection...
Dark picture and can't adjust from remote
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2011 | Philips 50P8341 50" Rear Projection...
I cant get into my camera function
From the BlackBerry Curve 8520 Home screen, press the Camera key on the side of the phone > Press the Menu key > Scroll to and select Options > Scroll to and select the desired setting: * White Balance : This setting changes the contrast of the pictures taken to optimal for the listed conditions:
o Automatic: The device automatically adjusts the contrast for each picture.
o Sunny: Ideal for outdoor pictures on a sunny day.
o Cloudy: Ideal for outdoor pictures on a cloudy day.
o Night: Ideal for pictures in low-light conditions.
o Incandescent: Ideal for indoor pictures with incandescent lighting.
o Fluorescent: Ideal for indoor pictures with fluorescent lighting.
* Picture Size: To change the size of pictures taken. Larger pictures require more storage space.
o Large (1600 x 1200)
o Medium (1024 x 768)
o Small (640 x 480)
* Picture Quality: To change the quality of pictures taken. Finer quality pictures require more storage space.
o Superfine: Best quality
o Fine: Medium quality
o Normal: Lowest quality
* Color Effect
o Normal: To take color pictures.
o Black & White: To take black and white pictures.
o Sepia: To take pictures with a sepia tint for an old-fashioned look.
* Store Pictures: This gives you the option to store pictures you take to either the device memory or the media card, if available.
* Folder: To change the default storage location for pictures taken with the camera.
After you adjust your BlackBerry Curve camera settings, pess the Menu key and select save.
Nov 19, 2009 | RIM BlackBerry Curve 8520 Smartphone
Very dark picture. Video adjustments do not help.
I would check the lamp first. Open the lamp door to see if there is cloudiness near the stem of the lamp. If so, replacing the lamp should make the brightness like when you first bought it.
Oct 11, 2009 | Sony KDF-E50A12U 50" LCD HDTV
Tv cloudy and faces are red
TV needs CRT coolant replaced, once this is done the focus and color level of each CRT needs to be adjusted for optimum picture. expect to pay around $300 good luck, Julio at Millenium TV , Las Vegas NV (702) 736-1091 milleniumtvsvc@gmail.com
Jul 21, 2009 | Philips E-Box FTR9965 DTV Receiver
Tv has lost it's brightness, dark scenes are almost unviewable
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Feb 22, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Need to fix the color and screen
Nov 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Pitcture is Wavy
Sounds like the tuner is going.
Dec 05, 2007 | Akai PT4799HD Rear Projection Television
Dark picture
sony had a recall on this set see if this is one of yours
http://esupport.sony.com/perl/news-item.pl?news_id=24
Oct 01, 2007 | Sony KP-57HW40 57" Rear Projection...
Philips 9P5034C 50" Rear Projection Television Logo
327 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
