Vizio VO47L 47 in. LCD TV Logo
Posted on Jun 03, 2009
Vizio GV47L, How to replace fuses on motherboard? I have the fuses located, but never swapped these type of fuses before. Thanks
  • 1 more comment
  • Anonymous Jul 22, 2012
    I went to radio shack and I was not able to assemble one. I was not able to answer their question on how many watts. I can see the fuse read 1.5 Amps. now the watts. Can you explain some details on this. Thank you
  • Anonymous Sep 10, 2012
    Someone else posted what they thought was the model number for the fuse. Loos like 125Volts. Here are the detailshttp://www.mouser.com/Search/ProductDeta... I'll be looking to try this today or tomorrow. I'll post with my results
    I go the inline fuse and a 1.5amp 250 volt fuse. I don't think a 1.5amp 150 volt glass fuse exists.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6693
Points
8
Fixed my 47" GV47L for $7.18... Did the F3 Fuse bypass solution, and it worked like a champ!!! No problems since! The part that took the longest was the drive to Radio Shack!!!Vizio GV47L, How to replace fuses on motherboard? - r_to_the_k.jpg
My 2007 Vizio GV47L FHDTV10A 3647-0012-0150 keeps blowing the main board micro fuse #1 Vizio logo lights up and menu lights up too, but have to unplug TV to turn off?
Does it blow the fuse with the LVDS cable removed? It it doesn't replace the tcon board if it has one, if it doesn't it sounds like a panel issue
Vizio GV47L flatscreen TV has no picture although it will power on
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
I'm have a vizio TV model gv47l fhdtv10a,I need
call any tv place they have new installation kits thatyou can buy
Number one fuse on my main board is deadl vizio gv47l hd tv 10 amp
If fuse is dead, there must be some reason for that. Some short circuit or so. Without rectifying the fault, if you replace it with an other fuse, the fuse you insert will also blow out, and might make more faults to occur. The rating of fuse will be marked on the printed circuit board itself, very near to the fuse.
BLOWN FUSES FOR GV47L, NO PICTURE
the power supply board will need replacement if it has blown fuses. Replacing the fuses will only cause them too blow again unless the short in the power supply is fixed. You can get replacement power boards from www.tvrepairworld.com
My vizio gv47l went black. where do i start
Search on blown fuses for gv47l. There are three fuses that you can check (open the back of the TV) and if one is mad you can jumper it with another fuse. I did this nad it fixed my gv47l
2helpful
2answers
Manual
Go to this link and you can download one for free. Be sure to rate this response as fix ya thanks slinteriors. heres the link
http://www.vizio.com/products/detail.aspx?pid=20
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
