I've applied for my drivers license for renewal 4 months ago, at Veralem KZN, they still did not send me a notification that it is ready, how can i track it on line, i don't want to travel all the way unless i am certain that it is ready for collection, i'm from Ballito. Hope you can help. Thanks Emily Ferreira. e-mail: [email protected]
SOURCE: Renault megane clutch
Unsure about Reanult-specific app here, but usually the higher-deck faces the pressure plate. The springs on the disc are higher on one side. I'm sorry I don't know about Renault exactly.
SOURCE: 1991 Honda Accord Wagon
If the battery was dead for more that 36 hours, or if you had the battery out of the car for more than 36 hours, you will have to have it towed to a dealer and have the ECU anti-theaft system reset. It may be less than 36 hours. Maybe it's 12 hours. Something like that. Call the dealer and ask about it. They'll be gald to fill you in.
SOURCE: not really a problem wit the car but i do need help!
first of all you do not want to get caught while driving with an expired license I would recommend you get a cab or bus to get to the secretary of state and if you do not need this license right away and you have no points on your license you can reapply for them on line I know for michigan there is no time any more it expires on the day of your birthday
SOURCE: Toyota Tazz 1997. The driver side window does not
Hi tony, my name is Ben. The first time you do this it can be difficult but once you see how it's done you will be a pro at it believe me. Okay, there is a "C" shaped clip holding the winder handle onto the shaft. Usually the open end of the "C" is towards the part you grab to wind the window. There is a special tool made to remove the clip, or you can use a sharp pick such as an ice pick or a small screwdriver to pop it off. BE CAREFUL, when it releases it can go flying off into space never to be seen again. Carefully push the door panel outward and try to work your pick down to pop one end of the "C" loose. It is a bit difficult, but take your time and you can do it. Good luck, let me know if I can help you with any other part of this, Ben.
Testimonial: "Hi Ben, thanks for the quick response!! Just knew it had to be a simple answer. Have not tried it yet but I understand your answer so should be ok. Thanks"
SOURCE: 2001 DTS : battery drained
http://www.youtube.com/user/scottykilmer#p/search/0/B__DqK90IIc
This is an easy test for any car.
