D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point Logo
A
Anonymous Posted on Jan 27, 2014
Dlink wireless gateway router - D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point
5 Related Answers
Joed911
JDTec
  • 4338 Answers
  • Posted on Nov 19, 2008
SOURCE: DLINK DI-634M WIRELESS ROUTER USED AS A REPEATER?
No. Here is the help guide:
http://support.dlink.com/Emulators/di634m/help_men.html
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Anonymous
  • 611 Answers
  • Posted on Apr 04, 2009
SOURCE: how to connect ADSL 2 modem to Wireless Router
just change the ip address in the router and give the proper settings in the router
Anonymous
  • 1383 Answers
  • Posted on Jul 23, 2009
SOURCE: dlink wbr-2310 router no wireless working
you have to change your channelk type in your wi fi router.
For that access your router with following link
http://192.168.1.1 or
http://192.168.0.1
if you have belkin router
http://192.168.2.1
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
Thanks for using fixya.
Please rate this solution if it helps.
Anonymous
  • 404 Answers
  • Posted on Aug 09, 2009
SOURCE: cannot get dlink 524 wireless router to work with HN9000
Hi! I will be more than glad to assist u in this concern..if u bypass the router it will work, the reason why the modem wont talk to the router bcoz the router is not properly setup.. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
govinda123
Prashant M
  • 2278 Answers
  • Posted on Oct 10, 2009
SOURCE: I have a Gateway nv52 laptop and a dlink wbr 2310
So that means you are able to connect to the network with the ethernet cable only.
Did yopu try to connect to the wireless network ?
And if yes then what was the error message ?
Click Here for more info about wireless connection. Pl. go through the web site you will get the answer !
Testimonial: "Thanks"
2answers
I have windows xp the cd that came with dlink dir 300 want work on my computer so how can i install dlink?
to be able for you to understand the installation of your wireless router
go here : CLICK ME
complete installation,guide as well as some illustration are indicated
Opening a port for webcam
hi friend
here is the spcifaction of ur router see it
1helpful
I have a 2701HG-B gateway furnished by AT&T DSL I want to change to wireless\r\nWill my gateway work with wireless? I will have to install wireless cards in my computers what do you recommend? My...
You need a wireless router for you to use Wireless connection
I recommend DLINK, Belkin or Linksys router any of those will work.
you can still use wired connection because router has 4 ports for wired connection but if you prefer to use wireless then you need to buy USB wireless network adapter.
1helpful
I have a Gateway nv52 laptop and a dlink wbr 2310 wireless router. I can not connect to my network, but I can connect to my friends syslink. If I plug right in to the main motorola router, I get...
I have a D-Link/WBR-1310 wireless router. I
the manual can be found online
depending on your revision of the router click on the links to download the manual
WBR-1310
ftp://ftp.dlink.com/Gateway/wbr1310/Manual/wbr1310_manual_110.zip
WBR-1310_REVB
ftp://ftp.dlink.com/Gateway/wbr1310_revB/Manual/wbr1310_revB_manual_220.zip
WBR-1310_REVD
to check which revision you have see this
q_detail.jpg Where do I locate the serial number (SN), hardware version/revision information (HW ver), MAC address and model number? a_detail.jpg The serial number, hardware version/revision information, MAC address and model number, will be located on a label on both the outer box, and on the adapter itself, usually attached to the bottom of the unit.
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side: 192.168.0.1
Subnet 255.255.255.0
DHCP on: range 192.168.0.10 to .20
DNS Servers: 220.233.0.3, 220.233.0.4
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address: 192.168.0.10
Gateway address: 192.168.0.1
Wireless g range extender
Hi there ....
before anything else, can you please what is the version of range expander is is wre54g v1,v2,v3?
1) either which, please do verify your wireless settings of your DLINK router
-- the network name or ssid
-- security if you enabled any on your router
-- wireless channel
-- please check the default gateway of your router if it is 192.168.1.1
** please take note also that the best location for your expander would be inbetween your router and your computers
2) once you have gathered the wireless settings
-- you would need to manually configure your expander coz it didnt work .. Please remember that the LINKsys expander is designed to work with linksys routers, so it may or may not work.. I just need to set your expectations on this ...
3) once you have verfied the default gateway of your DLink router ... please reply to this thread and let us proceed in configuring your wre...
Thanks and good luck!
Setting up wireless security
ManualThis is a discontinued item. Your passwords can be  UN - admin PW - (none), admin, or public
Right click on your network icon for your dlink and click Status click support and whatever your gateway is put http://*gateway* in your browser and log in.  That is where I WOULD CHANGE YOUR password and setup your security.
James Mac
1helpful
Wireless router
Yes, you can use wireless router with the modem. I guess the actiontech DSl router that you have is also Wireless one. If so, you can use just the DSL router for wireless connection. If you really want to use Dlink router with it, Connect the ( WAN port ) of the Dlink router to the ( LAN Port ) of the Action tech modem [ modem(LAN)-->Dlink(WAN) ]. Once you do this connection, better to do power cycle ( unplug the pwr to the dlink first, then, disconnect the pwr to action tech - wait 1min and plug the pwr to modem, wait for DSL light to be solid , then put the pwr back to dlink ). Make sure DSL light on the modem solid, internet light & WLAN light on the link glowing.
- Make Hardwire connection between the computer to Dlink and check the ip address on the computer whether it acquires the ip address from Dlink and then check the internet connection on the computer, it has to work. if computer not getting ip from dlink, try restarting computer.
- If hardwire connection on the dlink works fine and check the wireless connection.
For wireless configuration or assistance you may check this link:
http://www.portforward.com/help/wirelessxp.htm
please feel free to ask, if you have any more assistance.
- Laxman
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
