I had the same problem didn't have a restore disk but you should have one that came with the system I restore mind with out the disk --( just type this in) how to restore pc are laptop to factory setting page will open follow instruction and once done you will be good to go let me no how you came out good luck
remove the computer cover remove the battery in the motherboard and switch on the computer remove the power to hard disk while doing it then switch off the computer replace the battery and switch on the computer while restarting press DEL and correct the date and time and click optimised defults then click save and exit it will restart the computer and bios will be reset to the factory defult
Hi, you could try updating your driver. Go to start, control manager, hardware then select device manager, if its there, click the + and right ckick your device and select update driver. Hope this helps
just run system restore option .in system tools you will get system restore option just selce the retore date when your system was working fine. apply it it will reboot the system and fix the problem.
Hi, Press F10 when you see the first screen on your computer. It will appear a menu that will guide you to recover the pc. The reason of this procedure is that Ztsystems meant to make simpler the procedure
