I need some links for my watch I cannot seem to be able to buy any
SOURCE: Adjusting clasp on a Timex watch
Check that clasp from both sides and you should see spring lug ends. Use small pin to get them out(by pushing in). When pin is out you can adjust bracelet.
Good luck
Arthur
SOURCE: Tag Heuer "link" woman's watch-- can't open clasp!
You just have to pull with more force. Decent watch brands always make clasps very tight.
The reverse of the strap
Step 2. Get a piece of string or ribbon and wrap it around your wrist. Snip
the string so that one end meets the other and measure this diameter.
Step 3. On the other end of the strap you will see the hook which goes over
the clasp - you will see the next picture. From this hook the measured distance
will be where the end of the string lies.
The clasp mechanism - the watch is to the right of the
Step 4. This is the tricky bit! Insert a small screwdriver into the hole on
the main clasp part, from the right hand side and bend it down towards the strap
thus opening the clasp. Do not insert a tool from the left side, under the
clasp and use the bar as a fulcrum; you will bend this rod and the watch strap
will not hook over it. Move the clasp to the desired position and gently locate
the ridge nearest the position. Once located, press down on the open clasp
until it clicks into place - voila!
Related posts:
