find a mobility scooter supplier in the yellow pages /on line and get one from there
check but most chargers are generic for the voltage of the scooter
Is itthe Mega Motion Travel Pal? If so it looks like a Pride Go-Go control panel, somost mobility shops should have & be able help you with the key. Click here for Travel Pal OwnersManual
Installing batteries with a higher amp output than is recommended may short out the fuses or fry the controller; it is not recommended that you interchange batteries between different types of scooters in order to prolong the life of the scooter.
have yoy checked that the battery is well pluged. meaning possitive with possitive and negative with negative. sometimes grasse is stock on the joints of electricity, so brush them with a metalic brush, that should solve the proble.
It is time to replace the batteries. Buy two, not just one. This scooter takes two 12 volt, 12 amp hour, sealed deep cycle batteries. If you replace just one, the charger will not charge them properly.
Take off the seat (pull upward). Turn the scooter on its side. Remove the six screws (2 in front, 2 under the foot rest, and 2 in the back. Unsnap the old batteries (one at a time) and replace with new. Be sure to keep the wiring as is, so you keep the circuit in series (not in parellel). In fact, before you remove the old batteries, label the connections (A to A, B to B, etc.) so you reconnect just as they were. Total cost is about $200. Time to replace is about a half hour.
