KitchenAid KUDS30FXSS Builtin Dishwasher Logo
A
Anonymous Posted on Jan 26, 2014
Kuds30fxss built in dishwasher contol panel leds do not light up and buttons are nonresponsive. The wash cycle runs and won't stop.
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on Oct 02, 2006
SOURCE: The "Rinse Only Button" will not function even after going through the "Cancel" cycle.
br, sounds like you have a stuck keypad. This would be the only reason it is switching to a different cycle. Catriver..post back.
Anonymous
  • 878 Answers
  • Posted on Oct 15, 2006
SOURCE: cranky dishwasher
You want to make sure that the dishwasher is level and secure first of all. Then I would look into the door latch assy. Sounds to me that you are not making all the latch switches when closing normally. When you are slamming it, you are making the switches. The heating element runs through the neutral side of switches, therefor if the switch is broken or the latch is not making, no heating of the water. This results in a default or very long wash time. Check this out first....Catriver..post back.
Anonymous
  • 1314 Answers
  • Posted on Feb 12, 2008
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
Anonymous
  • 3422 Answers
  • Posted on Feb 25, 2008
SOURCE: stuck in two minute drain cycle
It is possible that the unit has leaked.
I want you to please check THIS link it will solve your problem.
Don't forget to do the banging test mentioned there.
Goodluck..
Anonymous
  • 264 Answers
  • Posted on Apr 24, 2008
SOURCE: Dishwasher won't start KUDIO1ILBS
How old is this dishwasher that you are using? Is this under warranty
KitchenAid KUDS30FXSS Dishwasher won't complete cycle
Press the Cancel/ Drain cycle for a few seconds. The dishwasher should reset itself. See if this makes any difference. Also first turn the mains power to dishwasher off and back on.
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
KITCHENAID DW KUDS30FXSS - 18 months old, will not complete cycles. Runs for 15 mins and stops & lights go out. Cleaning tablet often left in dispensor.
See my problem and solution. Sounds like you, too, are having a problem with the main control board (computer chip that controls the dishwasher), which is apparently a common problem with this model dishwasher. The part can be found here, for $211 (tax + shipping), and they have a 30-day return policy in the event that it does not fix the problem. It's an easy DIY fix. Hopefully this helps!
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
2helpful
2answers
Dishwasher will not turn on, clean light is flashing
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Pots/pan light blinks alternately with the normal wash button. Sometimes the cycle will start and then the lights come on. Once they start blinking, the cycle stops and I can't get it to start again. ...
There is a trouble shooting document behind the kick panel at the bottom of the machine. Follow the steps to determine which component is at fault. It could be corrosion at the P1 connector:
My whirlpool dishwasher gold GU2475XTVQ0 had rapid blinking lights that started with the "4 Hour Delay" LED and changed to others when other buttons were pressed. The machine would not run. I followed the instructions located behind the kick panel and verified the keypad was the issue and not the control circuit by elimination.
The big surprise for me was that when I used a straight pin to resistance check all of the buttons, they checked out OK. I reconnected the 14 pin connector (P1) to the control and found that the buttons/LEDs were behaving correctly! I believe that pushing the straight pin into the 14 pin connector removed any corrosion in the 10 year old device and permitted the keypad to communicate with the control again.
I reassembled the dishwasher door and it ran with no problems. I was ready to replace the keypad for $150, but didn't have to!
1helpful
My dishwasher won"t wash. Help me, PLEASE???
Try pushing and holding the "Air Dry" button for at least 4 seconds. This should turn the control lock off.
2helpful
Clean light flashes 7 times
try doing button setting change from "Hi-Temp Wash - Normal - Hi-Temp Wash - Normal" sequence of button selections. This must occur within 6 seconds and initiates an internal diagnosis of the machine.
The process runs for about 19 min. and shuts off
During the process several LED's light up and several funtions start and stop.
If the machine has no broken systems, you should be able to open the door add some soap and the usual dirty dishes and carry on with normal operation. this is the method to reset the machine.
Most likely is that there were suds in the last cycle or the door doesn't close smoothly.
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
