First thing I would check is the solenoid valve. It's what the water line in the back is connected to. An easy way to test it is to remove the screws connecting the solenoid so it is loose from the refrigerator. Remove the 2 water lines going into the refrigerator from the solenoid, keeping the water line from your house still plugged into it. Get a bucket and while the open ends are pointed in the bucket have someone press the water dispenser lever on front. If it dispenses water into the bucket from one side it's good, if not, replace it. Please be careful of the wire harness that is connected to the solenoid. Any part of the bare metal on the contacts, when energized, carry120v and can shock you.
Hope that helps.
SOURCE: Ice dispenser only dispenses crushed ice
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
SOURCE: Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
SOURCE: hotpoint side by side frig-no water, no dispenser lights, ice yes, but no dispense
sounds like the board in the dispenser is bad and needs replacing now it could be a bad connection at the board
