Timex Expedition47761 Wristwatch Logo
Posted on Oct 24, 2007
Setting the hourely beep
Hi
I have lost the manual of my expedetion series watch, i want to set the hourely beep
and in the digital display i want date to be displayed instead of time. how can i do it
Thanks
Amod
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 27, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
423
Points
How can I set the date on my watch? I could set time and alarm but I couldn't set the date .
Hi ajcruz_h,
To set the digital time and date on your Timex, please follow the steps below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
I can't set the time
Hi erbuckles,
Timex Digital Watch
Hope it helps.
How to set time on a 1440 timex watch
Hi tsgoode99,
Timex Digital Watch
Hope it helps.
How do i change my timex wr30m from 24 hour to 12 hour display
Hi cbrichw,
To use 12- or 24-hour time for your watch, please follow the instructions below.
Hope it helps.
Would like to learn how to set time on on Timex 1440 sports watch
Hi danielrob676,
Timex Digital Watch
Hope it helps.
1440 date change
Hi jhnmeserole,
Timex Digital Watch
Hope it helps.
How do i set the time and date
Hi hernandez415,
Timex Digital Watch
Hope it helps.
We don't know how to set the 1440 sports watch
Hi katbil1,
Timex Digital Watch
Hope it helps.
2helpful
I am trying to reset my T Touch watch from Tissot and can not find book. need to reset time and also how to convert from metric to US standards, like ferinhit and from meters to feet.
SET TIME:
1. Activate Crystal
2. Tap center of screen until digital time comes up
3. Press and hold top button (+) until watch beeps, display will be flashing
4. Use + and – key to adjust time. If several hours off, hold appropriate key and
after first hour passes, only the hour hand will move.
5. Make sure the digital display shows A or P for AM or PM
6. When finished, touch center of screen again.
SET DATE:
1. Activate Crystal
2. Tap center of screen until date appears
3. Press and hold top + button until watch beeps and display flashes.
4. Use + and – buttons to change date to correct one.
5. Make sure to set time first, if you set date first, you run the risk of the date
changing at noon rather than midnight.
1helpful
9answers
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 • Watches
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
