Dewalt 18 Volt Compact Drill Kit Logo
A
Anonymous Posted on Jan 26, 2014
24 volt dewalt
Batteries not holding charge
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Dec 21, 2007
SOURCE: dewalt battery 18 volt
Are you sure it is the battery and not a charger fault, is the charger warm after it's beeen plugged in for a while?
HHM Service Centre
Anonymous
  • 313 Answers
  • Posted on May 29, 2008
SOURCE: I have two 14 volt
if the battery are more than 3-4 yrs old its time for the new one.
you can purchase replacement cell but no garranty.maybe the other cell will go again then it will be expensive.
muttandjeff
Allen Neal
  • 359 Answers
  • Posted on Dec 03, 2008
SOURCE: Dewalt 18 volt battery life
run all the way down before charging as far as possible then charge see if is any better
Anonymous
  • 474 Answers
  • Posted on Nov 15, 2009
SOURCE: i have a 18 volt xrp dewalt battery that it das
replace bat.try northerntool.com. i bought a couple of after market ones for mine and so far so good
Anonymous
  • Posted on Feb 24, 2010
SOURCE: Holding battery charge on 12v DeWalt batteries
Are batteries for the dewalt cordless drill interchangeable? Will an 18 volt battery fit in a 12 volt drill?
I have a dewalt 24 volt sds drill when attach the fully charged battery to the body nothing happens when i remove the battery from the body it starts to smoke
So what is your question. It sounds like you have a bad battery so try it on another tool. If it works then the drill is not working or assembled properly if the same thing happens then you have ruled put the drill and there is a proplem with the battery
Old batteries started not to hold a charge very long. I purchase 2 new batterys and still have the same problem. NOTE- i WAS USING MY TOOLS outside in 100 plus degree heat for weeks.
does the charger check out? use a volt ohm meter to check the chargers output. when you charge all four batteries us the meter to check the batteries charge. this should give you an idea where the problem is.
I HAVE DEWALT CHARGER DE9116.ITS OUT PUT VOLTAGE WITH OUT LOAD IS 51 VOLT.AND WITH LOAD IS 15 VOLT.THE BAATERIES BECOME VERY HOT WHILE CHARGING
check output voltage on charger label most chargers are not regulated so if it says 18 volt output it may put out 24 volts but if its putting out 51 volts it may have a short batteries will get warm but not hot replace charger
Can dead battery dewalt be revived
Usually not. If the cells are dead and wont hold a charge there is really not much you can do except replace it or get the battery repacked with new cells.
Black & Decker 24 volt battery will not hold a
Click on the link below and you will find replacments
You need to work out if the cost of two batteries is cheaper than a deal on a new drill pack
http://www.svcvacuum.com/black_and_decker/black_and_decker_battery.htm
2answers
How can you recharge a 18 volt xrp when dead
You should buy new and return [as]defective one. Hint
Please rate a Fix ya
I had the same problem, the batteries are burned out, I know you can replacements at Home Depot but if you can wait try the interenet.
"Google" what you want.
4helpful
4answers
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
