SOURCE: limp mode
This must be the turbo version.
The epic pump was fly by wire and suffered from water getting into the plug on the back of the pump.
Try removing the plug and check. If wet dry out and try.
Also the throttle pedal potentiometer used to fail, so the engine would only tickover and not rev up.
TL
SOURCE: Hi ,Ihave a diesel focus
I think you are on the right track. The solenoid should make some kind of noise when engaged or shutt off. Be sure you have power at solenoid with key on and tap on it with something. If it dose not engage it probably is the solenoid. good luck
SOURCE: where is fuel filter for
this picture hope help you.
http://chinasinoy.com/service/location-of-a-fuel-filter-68.html
SOURCE: Turbo diesel Transit stalling, fuel?
A CLOGGED FUEL FILTER WILL CAUSE THAT START BY REPLACING FUEL FILTER
