Korg M50 61-Key Music Workstation Keyboard - M5061 Logo
Leonardo Griego Posted on Jan 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Korg m50 freezes, read in other forums that the problem may be to replace 2 capacitors, do anybody knows wich ones? or have a solution?
David Gust
Level 2:
Sergeant:
  • Expert 181 Answers
  • Posted on Nov 30, 2018
David Gust
Expert
Level 2:
Sergeant:
Answers
181
Questions
0
Helped
70053
Points
779
My opinion is that the capacitors are in the power supply. If they get old, they leak (electronically) and pull down the power output of the supply. They will be larger than any of the other capacitors in the circuitry.
2 Related Answers
Anonymous
  • 11 Answers
  • Posted on Feb 28, 2011
SOURCE: Where can I get the Korg m50 service manual or
http://www.korg.com/SupportResults.aspx?productid=413 just click here :)
Anonymous
  • Posted on Sep 22, 2011
I was just on the phone with partsisparts.net 800-590-0014 and they said the m50 service manual will be availible for purchase and download on their website tomorrow (9-23-11) I hope this is true. as for a parts list for the M50 I am still looking for that myself. I hate the poor quality of Korg.
My korg m50 audio output R-L MONO VOLUME OUT IS TOO LOW
Might be a case of opening up the M50 as the previous poster did and wiggle connectors and components until the sound is affected. If you have some electronics experience, it should be fairly easy to figure out which board to investigate.
Jun 10, 2021 • Korg Music
1helpful
2answers
Why is gm voice not playing?
Hello, You may want to reset your machine, all data and pre loaded programs, for this you must turn on your M50 press the global mode button, click on the top arrow next to (basic) select option 2, load pre-preloaded demo data, you then choose all (PCG and demo songs). press OK. Your Korg will re install all factory samples, data and settings. Once completed It will then instruct you to turn off your machine. give it a minute or so to self upgrade before turning it back on, once you turn it back on you should see updating panel notifications right and left, you should be able to use all of the sounds and combi's available for M50. that's a factory reset. I hope this helps, Have a great day.
My corg m50 board not orking gm not ork
Your best bet would be to contact Korg directly. Here is the link to their USA support page
Contact KORG
Hello, I own a Korg M50 myself and I had the same issue, its a quality control issue at their factory but, I may have a solution for you I found at a Korg forum. the issue is with these teeny cables inside the synth. you open the rear panel and firmly press each teeny cable into the terminals again and re attach and secure them firmly just finger push them all into their teeny sockets. this should stop the freezing I tried it the synth played all night with out freezing . I hope this helps other wise the solution with the capacitors is simple you order a new mainboard but they run about 400 plus. but try my solution it may work for yours this answer comes from a korg tech, he stated 90% of this freezing issue he has encountered has been these loose teeny cabling adapters, hope this helps, Have a great day..
2answers
Korg M50 keeps freezing up how to fix took it to repair and it still does it
Well looks like you have a capacitors problem. I had this problem too and a friend soldered two new capacitors in place. You can find information on the korg forum but most important is to know where the capacitors are located
http://www.korgforums.com/forum/phpBB2/viewtopic.php?t=92395
Korg m50 freezes after 10minutes
Hello I have this M50 61 key korg model, I had the same issue the fix is simple remove the back cover on the unit, carefully push in all the small cables reattach them well do it to all the small connectors these cables get lose and cause this issue, good luck let me know if that helped I fixed mines that way its been working excellent since. good luck..
2answers
How to reset the korg m50
PLEASE HELP ME... this appeared in my KORG M50.. says. LOADING OS FAILED..... Is ther a solution to this...
3helpful
2answers
Where can I get the Korg m50 service manual or parts manual?
Our church has a Korg M50-88 synthesizer. The sustain quit working and we have tried 7 different pedals. Any suggestions?
Refer to page 222 in your PA800 user manual regarding calibrating the polarity of the damper pedal. The setting in your unit MAY have gotten clobbered.
It is NOT clear if you have a PA800 or M50-88. If you have the latter, then read page 22 of your user manual where it says in certain modes the sustain can be set to affect only certain voices. Again, see if internal parmeter settings may have been clobbered to disable the sustain.
Top Korg Music Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Korg Music Expert? Answer questions, earn points and help others
