Timing marks 2000 Toyota corolla (4E-FE/ 4A-FE/ 5A-FE)
Align the crankshaft pulley mark with the 0 mark of timing case.
The camshaft sprocket is at TDC when the hole in the sprocket lines up with the notch in the bearing cap
Timing marks 2000 Toyota Corolla (1ZZ-FE/ 3ZZ-FE/ 4ZZ-FE/ 2ZZ-GE)
Set the Crankshaft key in 12 'o Align yellow timing chain mark
Clock position (The key aligns on the crankshaft sprocket
with the mark on the oil pump (see arrow)
body (see arrow mark)
Align the marks on the sprockets Place the crankshaft angle plate
with the yellow links of the timing with the marks B or F, facing
chain. towards you.
