System bought in 2000. Was used for a year. Then stored for 10+Yrs in attic. Hooked it up and worked fine. Moved recently. Re-hooked at a new location now sub not making any sound yet power light goes on. Wiring exactly as before. Tried different wiring techniques and nothing. Receiver is a snot also bought in 2000 and stored in same manner.
SOURCE: Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
SOURCE: no surround sound on ps3
Set the sound out put on ps3 to the optical out put then set sound on ps3 to give you dolby digital,dts,aac etc.
PS, do not set the hrtz range above 100 as this can damage your speakers.
hope this helps.
CABLE GUY.
