Question about Lexmark X6650 4-In-One Wireless InkJet Printer
Document hangs in queue lexmark x6650
Prints one document good then second request will say printing but nothing happens
6ya staff
SOURCE:
Anonymous
SOURCE: document printing hangs at 99%
same problem. everytime i restarted my pc and deleted the printed files from control panel/printers/lexmark x5150.
Posted on Jan 07, 2008
slywil091
Sylvester Osigwe
  • 112 Answers
SOURCE: Three weeks ago, I purchased a Black (No.4) and a
ok what should do is when you finish printing one page wait for some few mins before printing another page ok. that could help or unistall and reinstall your printer again and apply this method i just showed you. thanks
Posted on Jul 02, 2009
techbuster
INDIRA KUMAR
  • 5081 Answers
SOURCE: Document won't delete from printer queue after printed
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side window.
On the left side click stop the service and wait forthe process to stop .Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them depending apon how many print jobs you submitted. You will have to resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
Posted on Aug 19, 2009
s_4u_11
sandip panchal
  • 535 Answers
SOURCE: I can't delete a document in the queue for
remove usb cable from the printer then try to cancel it then after switch off your printer then after trying to cancel if problem occurs then u have remover your printer driver and reinstall it
Posted on Nov 14, 2009
Testimonial: "thank you very much "
printmastert
Lexmark
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: My printer won't print...there's a document in
    Try these steps to remove the print jobs stuck in the queue. Follow the instructions carefully:
    First, you have to stop the Print Spooler. To do this: 1. Click on the Windows logo start button. 2. Go to Control Panel 3. Open Administrative Tools 4. Open Services 5. It will pop-up a Services window. Scroll through the list and look for Print Spooler. 6. Double-click on Print Spooler, and click on the Stop button. Click on Ok button. Set the window aside.
    Second, you need to clear the print jobs in the Spool folder. To do this: 1. Click on the Windows logo start button. 2. Type Spool in the Search bar. 3. Open Printers folder 4. Delete all the files in the Printers folder. Close the window.
    Third, you have to re-enable the Print Spooler. To do this: 1. Go back to Services window. 2. Double-click on Print Spooler, and click on the Start button. Click on Ok button. Close the Services window. Click on the Windows logo start button. Go to Control Panel and open Printers folder. Refresh the page. That should clear the print queue now.
    If it still won't print, make sure to clear the print jobs in the queue again and try to reinstall the software. If you need more assistance, leave a comment and I'll get back to it. Thanks.
    Posted on Jun 21, 2010
    My epson wf 2630 printer is in an error state I send documents to the printer from my laptop but nothing happens I can not get it out of an error state
    If you have sent more than one document that has not printed, you need to click on the printer then see what's
    in the print queue and delete all the documents that haven't printed. If documents are "hanging" in the print queue it won't print. Only one document can be in the queue at one time..
    Dec 06, 2017 | Epson Office Equipment & Supplies
    Do i need software like ocr so that the lexmark x6650 scanner can work
    If you are scanning documents for editing or saving them as PDF, you will need to install the OCR scan software. The Lexmark OCR scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center to request for one.
    If your scanner was working before, it could be just a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
    If that doesn't help, try the steps below:
    1. Disconnect the USB cable connecting the printer from your computer.
    2. On your computer, go to Control Panel > Printers and Faxes.
    3. Delete the Lexmark print object.
    4. Reboot computer.
    5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
    6. When the printer turns on, reconnect it to the computer.
    7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to scan a document again to verify that the problem is fixed.
    Nov 02, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
    Will not print all conections are good every thing sits ,but does not print have 9 documents pending
    Hi. You will need to clear the queue first as it will just accumulate in it if the pending documents remain. There are articles in the Lexmark website to help you remedy the problem. Just click on the links. This first link: http://bit.ly/agrrFg will help you remove or cancel print jobs in Microsoft windows. If the print jobs are still stuck in the queue, click on this link: http://bit.ly/aVuCwm and follow the instructions carefully. Once the queue is cleared, unplug the printer usb connection from the computer and plug it back in after 5 seconds. Try printing again. Good luck!
    Mar 24, 2010 | Lexmark X4270 All-In-One InkJet Printer
    Printer wont print. help!!
    Hi albookristin
    I believe evrytime you tried to print, they all lined up in a queue for printing. If that is the case, you have to delete everything in the queue
    Right click on the printer folder, look under documents, and see there are documents listed. If there are few, delete all of them. In some cases, you may have to print one at a time.
    After doing all that, try to print a document. For test purposes type a one line document and try to print it.
    Hope this will work for you.
    Have a good day
    luciana44
    Nov 15, 2009 | Lexmark X2500 All-In-One Printer
    My lexmark x6650 is giving me a "cannot retrieve application list" error when i try to scan from my mac. what does this mean? what do i do? jim
    You have to Open System Preferences > Print and Fax > Options and Supplies > Driver > Print Using : select a driver to use - select Generic PCL LaserPrinter > OK
    Now You can try printing a document using the faulty application, immediately after hitting Print pause the printing in the printer queue (use the printer icon which has now appeared in the dock). With this panel open hit Info > Driver > Print Using : +select a driver to use+- select your printers driver eg.Lexmark x5400 > OK > Resume
    The document should now print as normal
    Oct 11, 2009 | Lexmark X5470 All-In-One InkJet Printer
    DOCUMENTS FOR PRINTING DON'T GO INTO A PRINT QUEUE
    If you mean that when you go to print a document it doesn't hang in the Windows print queue and leaves quickly, then it is because either the printer has grabbed the document into its memory or it has sent the document to what it thinks it another printer. It might also be that the drivers you are using are not set correctly or that the connection to the printer is incorrect.
    Jul 09, 2009 | Lexmark E232 Laser Printer
    Three weeks ago, I purchased a Black (No.4) and a Colour (No.5) Valuepack Cartridges for my Lexmark X2690 All-In-One printer from Refresh Cartridges/UK. After installing both cartridges, I printed a Test...
    Jul 02, 2009 | Lexmark X2690 All-In-One InkJet Printer
    Printing errors
    Try printing one page at a time and see what happens. Repost!!
    Jun 15, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
    When printing documents from my PC documents always sent to queue
    Go to control panel, printers. Set your defaults there. You probably have spooling enabled. Uncheck it and your print job will go to the printer, rather than to spooling. Spooling is like rolling the print job up on a spool until the whole thing is processed, then unwinding it to the printer.
    Feb 17, 2009 | Lexmark X3550 All-In-One Printer
    Lexmark C1150 printer doesn't print
    First I try to uninstall the printer, it didn't work, so I reinstall the the printer anyway, it worked for one print only.
    As second attempt I disconnected the printer completely, turned the PC off, and after few minutes on again. Uninstalled printer.
    Reconnected the cables again, install the printer - it works well!
    Dec 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
    Lexmark X6650 4-In-One Wireless InkJet Printer Logo
    Top Lexmark Office Equipment & Supplies Experts
    Clive
    Clive
    Ekse
    Thomas F. Schneider
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
