Pride Jazzy 614 Hd JAZZY 614HD Logo
T
Tasha Southall Posted on Jan 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is a left brake fault?
It say left brake fault may not be engaged.
Rob Hill
Level 3:
  • Pride Master 1,480 Answers
  • Posted on Feb 03, 2014
Rob Hill
Pride Master
Level 3:
Answers
1480
Questions
0
Helped
517726
Points
3838
Hi, the brake on top of the motor on the left hand side ...
Regards
Rob
www.gewizrepairs.co.uk
1helpful
My M41 invacare controller keeps flashing and it flashes 5 times. I don't understand what the fix for this.
If your M41 has the mark V controller that is seen pictured in the stock photo you provided, the 5 flash code is a left park brake fault.
1. Turn off the chair.
2.Disengage the left motor (levers are located in front under the seat) roll the chair back and forth and re-engage the left motor.
3. Engage the left motor.
4. Turn on chair.
If you happen to have the older Mark IV controller (has a toggle switch to turn on/off and three battery lights), the 5 flash code means the chair is receiving high or low voltage from the batteries. I would recommend having the batteries checked.
If the chair stops flashing, you are good to go. If the chair is still flashing, you will need to contact a technician to possibly replace the left brake. I recommend Repair Xpress FixMyPWC com Nationwide service and delivery solution for power...
ABS engages without braking
Check all wheel sensors for broken wires, loose connectors or position of sensors in their mounting brackets.
Left brake fault may not be engaged.
Each motor has a brake system attached to them. One of them isn't working and is sending a fault signal to the controller. It needs to be serviced.
7helpful
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Emergency brake will not engage left blinker will not blink just stays on
It sounds like you back brake shoes may be worn out, which could cause the emergency brake to not engage. The left blinker socket may need to be replace, or your blinker switch under the dashboard in the fuse panel that may need replaced.
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Sometimes, out of the blue, when i snap on my M91 and touch the joystick, i will here a faint click and the power display will start blinking. the machine will NOT move. any ideas?
With the M91 the click you are hearing is the electric brake solenoid engaging and disengaging the electro mechanical brake. The display blinking probably indicates a brake solenoid fault code and right or left motor. Try working both brake levers back and forth listening for and feeling for smooth action. If the levers are bent and the brakes are not working a motor replacement is necessary. If you can identify the fault flash code you can determine which brake or motor is the culprit and use a DVM to verify the component failure.
The Front Pad Brake is jamed on and is bearly impossible to release
hi stephen,
are you using a v-brake or a disk brake?
if a disk brake, is it mechanical or hydrolic?
what is the brand and model of your brakesets?
most mechanical's fault is the magnet on the brake pads mount, when these wear off, or is dirty, it will not have anough power to pull the pads when used.
most hydro's fault is on the piston, once the brake is engaged and the piston gets stuck, you end us on the stuck brake. to have this resolved, clean the assembly, replace components if needed. you may first bleed the brakes and leave it engaged overnight. if the piston gets stuck again, check for fragments on the set.
hope this helps.
regards,
voodoo
5helpful
2answers
Handbrake indicator light
I'm sorry but i laughed in dismay when I read your problem. The dealer is an idiot clear and simple. It is perfectly reasonable for you to expect the handbrake to be disengaged if the indicator is off.
Yes it is quite possible to drive the car with the handbrake on but you would feel it no question. However if it was only slightly engaged there would indeed be some wear on the rear brakes. The handbrake has merely got a thin metal cable that runs underneath your car that splits into two separate cables which in turn connect to the rear left and right brakes. So there aren't any extra brakes for the handbrake just the ones which are on the rear wheels.
Of course the other thing is you may have a faulty handbrake indicator light. So it's not really about who's fault it is but where the fault lies on the car. I'd go and check out a local garage unless of course your car is still under warranty.
If it is go to another dealer and armed with the info above don't let them fool you
Good luck and i hope you get it sorted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
