Machine keeps stopping after being given a load to dry and beeping ceaselessly. We clean all the filters, empty reservoir (not full in any case) and it sometimes works or sometimes just runs for a few minutes then stops and beeps again. Sometimes the anti-crease light is flashing when you restart...
SOURCE: bosch maxx wtl 6300 dryer when
Hi Guys...
At least I can shed some light on how to open the bottom part.
When you are looking into the dryer with the door open, take a look at the bottom hinge of the door. There is what looks like to be button popped out slightly..
Place your thumb on it and press. This should open the bottom part of the dryer. Then clear out the gap between where the lint filter connects to the other units below it (when the door is closed...)
Hope this makes sense... there seems to be a sensor there..
I just cleaned mine so praying that the beeps stop.. Its been driving us mad for the last 8 months!
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
I had the same problem and figured if the lint sensor is clogged, covered or otherwise gummed up with lint, dirt, hair, etc then this will continue to happen regardless of wether the lint trap is clean.
So I took my compressor and blew out the slot where the trap slides into...stuff flew everywhere (so watch your eyes or wear goggles). I then vaccumed it up and did it again... and again and again each time loads of stuff came out. Once nothing blew out I loaded the dryer and have not had the problem since...
This makes sense right? so if you can try this solution.
SOURCE: Fisher & Paykel ED56 not working
Replace (repair) the exhaust sensor this looks like a transistor with the middle leg cut off. it is situated below the lint filter but can only accessed by removing the back panel, top panel (or rear screws to allow the removal of the drum). drum and then front panel to remove the connector from the mainboard. If you follow the exhaust tube once the back is off you will see a single phillips head screw that is the sensor. check the wires to the circuit board are not broken or dry joints or just replace it. sorry i had a spare machine i scavenged from to fix my problem so i dont know where to buy new.
