Water Heaters Logo
A
Anonymous Posted on Oct 05, 2017
Jacuzzi wood stoves the handle is very tight to turn is a brand new stove first season used , all of a sudden handle is so tight can hardly move it any suggestions would be great, have tried wd40 but no go .the first week we used it handle got tight then just returned to normal but this time seems to be staying very tight. thanks
1 Related Answer
Anonymous
  • 61 Answers
  • Posted on Dec 01, 2008
SOURCE: wood burning stove with integral burner not heating the water eno
When is the last time you brushed out the burner tubes of the boiler? This is how heat transfers and if you have a coating of soot, it will prevent heat transfer. check this and post me back
Truma water heater water wont come out of the taps when on gas, 12 volt or mains 240 volt
Bleed your propane system by running the stove for a sec. if that doesn't work go out to the heater and listen for the ignitor clicks see if it's trying to lite. My fifth wheel does this first time every season.
Which brand should i buy for an electrical built in stove
All I can say for those glass top stove is they look nice.
The splatter near the cooking area gets very hot and bakes on. Need to scrape off with a single edge razor then a good abrasive cleaner like "diamond magic". Without using a razor, one would not have enough elbow grease to clean like the pretty stove you bought.
How do i get even heat thru out the house with a daka wood stove
http://www.hearth.com/talk/categories/main-hearth-forums.4/
You burn wood, and smoke goes up flueway.
You're not running chimney smoke through ductwork so you have a heat exchanger.
What kind of heat exchanger?
probably air since you're running through ductwork?
How much hot air or hot water is coming off heat exchanger?
How big of a space can be heated with that amount of heat?
Is the exchanger located in optimal location?
Considerations.
One room log cabin with fireplace will not stay very warm.
One room house with big wood burning stove in center, with hot flue pipe running across the room and exiting on far wall, will get warm-hot, but will cool off fast.
Why?
Because the BTU output of firewood is much less than electric, coal, oil, or gas.
Otherwise they would have made wood-burning steam locomotives. But the locomotive boiler cannot get hot enough with wood ... the boiler needs coal to produce enough BTUs to boil water fast enough to rotate the turbine and turn the wheels.
Maybe your wood stove output should be measured.
Don't forget a huge percentage of fire heat goes straight up flueway.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Bought a used lp gas heater stove for living room.need istructions with pictures on how to install the vent. did not come with a manuel and unable to find info needed on website. this is an Empire Cast...
You have this posted under the Z-vent heading... is that the make pipe that came with the stove, and if not, what vent pipe came with the stove... we need to know which pipe it is exactly to be able to help you best...
heatman101
Stop 2min and run for 2min, stop 2min and run for
your motor thermal safety relay is protecting the motor from burning out
this is usually caused by: an old motor about to fail (tight shaft bearings) bad centrifical switch or, an obstruction in the water flow causing the motor to work too hard (draw too many amps, get too hot then cool down and, start up again
check the relay it is located on the side of the motor on most motors; under a cover; unless the motor is bad the relay may just be too sensitive (old) and, may need to be replaced.
I purchased an aqua star 1600h-lp to be installed in a cottage. Question is, the cottage is heated with a large wood stove/fireplace. The water heater is located in a bathroom at the other end of the...
I would say that the wood fire/stove must have a heck of a draw to affect the bathroom heater. Maybe a separate air supply from outside via a pipe,to the stove meshed off against vermin would decrease the problem. Plus it could stop cold air being sucked across the room from an outside door.
Downdraft through the heater could happen with either vertical or horizontal vent. More important is the direction of the prevailing wind [horizontal] ingress of water/snow etc [vertical]
We often use the separate air supply in the UK and if the pipe bore is large enough 4" plus it seems to work ok.
Wood burning stove with integral burner not heating the water eno
Top Jacuzzi Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Jacuzzi Water Heater Expert? Answer questions, earn points and help others
