Pyramid (Swr14) Swr&Power Field Strength Meter with Power Switch (10&100 Watts) Logo
Posted on Jun 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Roadpro swr meter is not responding when i connect it
Its the 2c model. i am trying to calibrate a magnum s-9 cb radio. and i lost the directions
DROPNDEAL
Level 3:
Top Expert:
  • Pyramid Master 2,931 Answers
  • Posted on Feb 10, 2018
DROPNDEAL
Pyramid Master
Level 3:
Top Expert:
Answers
2931
Questions
0
Helped
932553
Points
21770
Well...Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
roadpro swr meter is not responding when i connect - helpful-j2fqtt4x4km4a1x1cbly0mof-5-0_11.png
2 Related Answers
Anonymous
  • 5158 Answers
  • Posted on Feb 01, 2009
SOURCE: need frequencies covered by pyramid SWR-14 meter
it appears to be only good for the cb frequencies.... i suspect it would be too unstable for 2 metre usuage
Robert
Please take a moment to rate this solution.. thanks
Anonymous
  • 6771 Answers
  • Posted on Apr 16, 2011
SOURCE: I have one of these
This unit was designed for cb operation only, using it in the two meter band range will cause unstable readings and accuracy issues and risks overloading the rf finals. I strongly suggest a proper ham unit for calibrations.
Roadpro rpswr
What was the radio that you keyed?
AVAIR 601 instruction swr meter
the two you have pictured are close but no cigar.
Which pots do I use to calibrate swr and rf meters on 29classic to match extral meter?
VR5 tx power meter VR6 antenna warning light
There is not pot for swr cal internally. I guess the cal knob broad range pot or variable resistor. Swr readings after user calibration knob on front of radio, for meter should be close. Obviously not as good as external with larger scale meter. If you can not calibrate meter on face with this knob your radio may have less than 4 watts deadkey.
Just to be on the same page. Understand that SWR is a reading of antenna system condition or tuning of antenna to vehicle mounting location. This is a brief description.
2answers
1helpful
John Q president cb
If by calibration, you are referring to the check if your antenna is tuned, below information may be of help.
S/RF/SWR/CAL SWITCH. When in the S/RF position, the meter swings
proportionally to the strength of the received signal. When transmitting,
the meter indicates relative RF output power.
When in the "CAL" position, the SWR meter can be calibrated by adjusting
the "SWR CAL" control to the "CAL" mark on the meter face.
When in the "SWR" position, the standing wave ratio is measured.
SWR METER. Measures standing wave ratio of the antenna system.
Used to properly adjust the length of the antenna and to monitor the
quality of the coaxial cable and all RF electrical connections. If there is any
degradation whatsoever in any of the foregoing, due to humidity, salt
spray, vibration or corrosion, the SWR meter reading will rise, thereby
indicating that a problem exists.
To calibrate, switch to the "CAL" position, transmit by pressing the mike
switch, and adjust the SWR control to the "CAL" mark on the meter; then
switch to "SWR" position for the SWR measurement.
If however you are referring to the internal calibration or tuning of the transmit and receive sections, you would need several instruments/equipment such as RF generator (0-30Mhz with 1Khx modulation), Spectrum Analyzer, Modulation Scope, Dummy Loaded Wattmeter, Frequency Meter and some others. These of course are not readily available to the average user.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
9helpful
2answers
SWR calibration waaay off the chart
You are using an inline swr meter to set your swr right, not looking at the meter on the radio? Here is the process to set swr on an antenna:
You must have an inline swr meter, which can be purchased online or from a truck stop. The ones at truck stops are cheap ones, but will do the trick for the most part.
You connect your antenna 18ft coax to the antenna plug of the swr meter, and a jumper coax (any length) to the transmitter plug of the swr meter and then to the radio.
Close all doors and make sure no one is messing around with the vehicle or antenna. You must be set up as you would normally be transmitting.
Now set your cb radio to channel 40 and your swr meter to fwd. Key up your microphone1.gif and at the same time turn the set knob on the swr meter until the needle is at the line that reads set. Unkey your mic and set the the swr meter to ref. Key up again and note what your reading is. Now leave the swr meter in ref and turn the cb to channel 1. Key up and take your reading. If the reading on ch 1 is higher than ch 40 you must raise the stinger on your antenna. If ch 1 is lower than 40, you lower your stinger. You are trying to get lower than a reading of 3 and as close to 1.5 as possible. If you lower your stinger as far into the antenna as it will go and you need it shorter, you cut the bottom of your stinger no more than 1/2" at a time, and recheck your swr reading after each cut.
Once you have gotten the best reading you can, connect your antenna directly back to the radio.
The setting of your swrs is to make your antenna as efficient as possible, by trying to get it as close as you can to a 50ohm impedance. THE ONLY PART OF YOUR SYSTEM THAT CAN CHANGE YOUR SWR IS YOUR ANTENNA, not your coax and not your radio. Your radio and coax can give you false readings, but only the antenna can actually change the swr.
On the swr meter, the fwd/ref switch stands for forward (power that is being transmitted out) and reflected (power that is reflected back into the radio.
Just for information sake, the swr cal switch on your radio is used to set the meter to reflect the swr that your antenna is set at. The meter on your radio is like a dummy light on your car. ONCE AGAIN, YOU CAN NOT SET YOUR SWR ON YOUR RADIO, only the antenna.
Top Pyramid Car Audio & Video Experts
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
xxxxxx xxx
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
