How do i flash my phone
SOURCE: LG Rumor - stoping Sprint music on startup & shutdown
you just turn the voluem to SILENCE ALL, that should do it.
SOURCE: i wanted to download songs onto my phone from my
Ok first you would like to connect your phone to your computer via the usb cable that came with the device, next on your phone go to menu>tools>more>mass storage>connect to pc. Then on you computer go to My Computer or Computer (depending if you have xp or vista). Then select the new mass storage drive that appears, it should say temp drive or flash drive then a letter for example; Temp Drive: F .. once you double click inside this drive select the music folder if you dont see it right away click inside the DCIM folder and you should see it in there... Then once inside the MUSIC folder just copy and paste the songs from your computer onto this folder and then you should be able to play them on your phone.
SOURCE: Need to do a master reset on my LG Lotus phone
Hi. Go to this link and do the hard reset.
http://64.211.90.9/iframe/tutview.seam;jsessionid=7EDF4EE9E99CE14D24F58039AE7CC897?tutorialId=1971&deviceId=664&cid=120388&conversationPropagation=nest
Regards, Joe
ps - kindly rate my answer as helpful. thanks.
SOURCE: Lotus will not send pictures after flashed to Revol
sometimes when phones are unlocked to be used on other carries portions of them will not work due to them not being compatible with the new service
