JVC GZ-MG130U Camcorder Logo
E
Epco Ongering Posted on Jan 26, 2014
My JVC camera got wet and does not start up any more. Can I recover files from the internal harddisk?
Camera got washed by a surf on a boat. some lights are still blinking, but the camera no longer starts up. I see no external Harddisk connection. Can I remove some screws to release the harddisk or is this a too simple approach of this problem?
4 Related Answers
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Jul 01, 2008
SOURCE: Transferring video from JVC Everio G harddisk camcorder to Sony DVDirect
Do both cameras have a dv connection to them?
Anonymous
  • Posted on Sep 24, 2008
SOURCE: driver for JVC GR-D290U
i need drivers jvc gr-d290u
zohail
Shoaib Rais
  • 1223 Answers
  • Posted on Feb 24, 2009
SOURCE: can't access/copy video files on JVC gz-mg37aa
do not format it in any case bcoz in that case u will lose ur data all videos try using it on vista see if it helps do not format it in any case tell me th eresults i will help u more
Anonymous
  • 10515 Answers
  • Posted on Feb 07, 2011
SOURCE: I have a JVC GZ-MG465BU
This is a common problem.Try connecting the old camcorder to your computer via firewire and turn it on. Look in the 'My Computer' file for the camcorder as an external storage device. If it shows up there you can simply copy the files to a temporary directory on your computer and view them with Windows Media Player.If the problem does not resolve, you need to send the unit to JVC repair center. Apparently, repair requires reformatting the hard drive which means they will have to attempt recovering all the files currently on the hard drive.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
2answers
Retrieving my pictures from camera wen i pressed format
there is a lot of recover software on the internet, here is one you can use, and the free version is ok : https://www.piriform.com/recuva/download
othervise try to look here on google search :
https://www.google.dk/webhp?sourceid=chrome-instant&ion=1&espv=2&es_th=1&ie=UTF-8#q=undelete
hope it helps or return here...
2answers
What program do I need to recover deleted vido from the JVC GZ MG 130 U camera?
I suggest you use Card Data Recovery. It can recover deleted video from JVC camera. This program is very easy to use with good function. Wish that can help you.
1helpful
Hello....I have a " JVC
here is the manual in pdf form.
I looked though it and it doesnt seem to have a solution. For this "video management file is broken." yet there are many people with this problem.
I would check to make sure you have updated the software since it is a harddrive camera
http://resources.jvc.com/Resources/00/00/91/LYT1591-001D.pdf
May 04, 2011 • Cameras
I ERASED A VIDEO ON MY JVC HD 1080P REC VIDEO CAMERA. MODEL NO: GC-FM1BU. IS THERE ANY WAY TO RECOVER IT?
If the original file was saved on an SD card then you can bring that SD card into a computer specialist and they can get into the card and recover deleted files. If you do go into a specialist, bring your video camera and USB cable as well in case it is not on the card because they may be able to get it off the camera too.
Sep 07, 2010 • Cameras
Accidentally deleted photos from internal memory of my Kodak came
Hi!
Let's try to save your son's halloween pics.
There are a lot of recovery software that you can use to recover deleted files - specially pictures. You can try to use Zero Assumption Recovery. You can download the software at this site:
http://www.z-a-recovery.com/download.htm
It's a free software (you do not neet to pay to use this), and it's easy to use.
Here are the steps that you need to do:
1.) After you install this software, connect your camera to your PC (do not insert the memory card). Turn on the camera, open the Zero Assumption Recovery software.
2.) Click Next. Select "Recover images from the digital camera.." and click Next again.
3.) Select the Physical Device - select your camera , click Next. [grab a cup of coffee since retrieving the files may take some time depending on the size of the memory (",) ]
4.) After retrieving the files - select all the files that can be recovered. Click Next.
5.) Select the button on the right side (close to Destination) and select where you want to save the files. Click "Start revovering files".
That's it.
I hope that helps.
Good luck and have a nice day!
4helpful
2answers
HDD error, full disk, camera temp is too low
I have had success with this... Download the camera recovery software called asoftech data recovery
http://www.asoftech.com/adr/
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
24helpful
7answers
Deleted Files?
First things first: DO NOT take any more photos or videos with your digital camera (memory card) that you want to recover files from in case you may quite possibly ruin your chances of recovery.
Then here are some software programs that may help you out.
For Windows --> Data Recovery Tool
For Mac --> Mac Data Recovery
Here are the steps:
1. Connect your camera (memory card) PC or Mac which has installed the recovery program.
2. Scan for the lost files (photos, videos etc).
3. Recover them.
5helpful
5answers
Cybershot DSC-N1 restore internal memory photos
You can recover deleted photos with camera recovery software like asoftech photo recovery, download from
Camera Photo Recovery Software
Please be noted that your camera memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
13helpful
4answers
Sony dsc n1 ,recover photos from internal album
I have had success with this photo recovery... Download the program
camera photo recovery program
you may refer to this tutorial
recover pictures from camera
3answers
Jvc gz-mg20 camcorder recover files
Don't give up on those files, the software I use has found files on the camera that I thought were deleted and it did discover them. And that was unintentional...
Adobe Premiere 4 is the program I use to edit my video and was the one that found the files...
Hope that helps!
If there's anything I can do to help, email me at [email protected]
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
