I trying to see why my front loader want go into wash mode when I press the start button on washer machine but it sounds like it's trying to catch to start the water to come in to start washing but nothing happen and all the lights on the machine is function correctly but it want go into let water run to start the wash
SOURCE: front load washer
Easy things first: Check the water hoses are all connected, the taps are on, and that the hoses aren't kinked. Everything after that involves poking around live terminals. If you aren't happy doing this, then don't be ashamed to call someone else in. Turn the power off. Remove the top panel from the machine. On the inside of the back panel near the top, you will find the fill valves (on a few machines, there is only the one). These are the items that the fill hoses you checked a minute ago plug into. Follow the hoses inside the machine from the soap dispenser back to the valves to identify which valve is the one which washes soap into the machine at the very start of the cycle. On the top of this valve are two terminals. Attach the leads of a multimeter to these, and select an ac volts range that will stand seeing mains voltage. (If you haven't got a multimeter, suggest you buy a cheap one from the local hardware shop - it will come in handy for all sorts of things once you have it). Turn the machine on and start a wash cycle. If the meter shows mains voltage across the terminals of the valve, and yet no water is flowing into the machine, you need to replace the valve. This is a cheap part to buy, and not difficult to do yourself. IF you don't find any volts across the valve, it's worth trying the other valves to make sure you haven't got the wrong one, but then it's beginning to look like a controller problem - at which point it's worth paying someone else to come in and look at it: Once expensive parts get involved, you either need to be sure you know what's broken, or be sure you can take unneeded, but briefly installed replacement parts back. Before removing your meter leads, don't forget to turn the power off. A.
SOURCE: Frigidaire front load washer (LTF600ES1) Error E20
holla, Im not showing a E20 code on the tech sheet. There is a E21. Water not draining fast enough. Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin leds should light. Any error codes should be displayed when holding those keys. If you see a different error code, post it. If not, I would suspect a clogged pump...Catriver.
SOURCE: front loading frigidare washing machine
Check breaker only one breaker are function recock it the two breaker try to start it .
SOURCE: frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
SOURCE: Frididaire (LFT2140FS) Front Loading washer - Did
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
