Need to know how to make it rinse and spin only
SOURCE: Washer doesn't stop
select a hot wash of some kind and check if the water heats. if not, problem could be heater or associated stat
SOURCE: washing machine not spiining
sump hose filter blocked, running out of draining time, when you put it on again it allows more time to drain, remove sump hose and clean out internal filter.
SOURCE: does not spin and rinse properly
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
SOURCE: My washing machine wont rinse and spin
A hotpoint WMA30 does not beep on any program as there is no 'beeper' on the pcb. The 'end' led illuminates when it finishes on any program. The most common cause of no rinse or spin is a blocked filter or drain hose. If there is water in the drum when it has finished then this is the probable cause. However if it's empty when finished and has not spun then either the belt has come off or the motor brushes are worn to a point that there is no contact with the motor armature.
SOURCE: My Hotpoint WF860 will spin on rinse/spin load but not on a wash
no its the programer at fult
