My tv has stopped showing a picture through the coaxial hookup and a couple of the video hookups
Please contact the authrized service center for Hitachi. Sounds like corrupted firmware. Firmware update is necessary, and the firmware to Hitachi is very difficult to get by internet. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
SOURCE: vhs hookup to tv
Try hooking up the AV cables, unless it's an older model(1993-1998) then you might require a coaxial cable. After this you simply plug it into the wall outlet, but I would suggest a surge protector for a Hitachi. If that does not work, then it is simply not compatible, but it should work, good luck
SOURCE: Can't plug in regular cable
go to wal-mart and buy a converter screw in cable comes out rca cables.ans ask if tv is a monitor or tv next time
It will show a picture if I hook up a laptop through the hdmi hookup. A couple of the audio hookups have also stopped working. This tv has 3av hookups and all 3 only one or the other works.
