Canon MultiPASS MP730 All-In-One InkJet Printer Logo
D
Dana Hacke Posted on Jan 26, 2014
Canon multipass mp730 printer will not power up
My printer will not power up, I have checked the connections are all okay. It is normally left on and then I went to use it and it was off.
5 Related Answers
old marine
old marine
  • 2426 Answers
  • Posted on Mar 16, 2009
SOURCE: is canon multipass \mp730/700 compatible with window vista
Windows Vista drivers are available here. Be sure and download/install both the driver and the MP Toolbox (listed under Software). If you currently have other drivers installed, be sure and remove them completely before trying to install the new drivers.
Anonymous
  • 6487 Answers
  • Posted on Jul 10, 2009
SOURCE: how do you install a multi pass mp730 printer
You can download the printer software from this link and then you can now install the printer to your computer using that software..
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=9035
Anonymous
  • 71 Answers
  • Posted on Oct 04, 2009
SOURCE: How to fix a message: Waste Ink Near Full
Instructions for resetting the MP730 ink tank full counter
1) Enter SERVICE MODE.By
pressing MenuCopy#
2) Select TEST MODE. using the + key then the set
3) Select [8] PRINTER TEST in TEST MODE. by hitting the number 8
4) Select 3. [EEPROM CLEAR]. by hitting the number 3
5) Select 0. [INK COUNT]. by hitting the number 0
6) Let it default to the new value by waiting
7) Press the [Stop/Reset] key (returning to the state of 3)), this is the red stop key
8) Then press the [ON/OFF] key and the machine will reset and push through a page of paper
Sometimes is need to clean the purge unit
Canon MP730 Printer Purge Unit Disassembly and Assembly :
http://newsquaremusic.com/CanonMP730PrinterPurgeUnitDisassemblyandAssembly.pdf
http://newsquaremusic.com/CanonMP730PrinterWasteInkTankFullResolution.pdf
I hope this is useful
randymanfive
  • 501 Answers
  • Posted on Nov 17, 2009
SOURCE: Jammed cartridge error froCanon MultiPASS MP730 All-In-One InkJet
You can open up the device and look inside. You'll prob ably find a jammed peice of paper or a paper clip or some obstacle inside jamming either the rollers or the track for the print head, or both.
pineworks
Clive
  • 4362 Answers
  • Posted on Feb 26, 2010
SOURCE: Canon MultiPASS MP730 All-In-One InkJet Printer Paper jam
Hello there Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
I have a canon MP730 and it is connected to my HP computer. I can print a word processed document and any material online onto the MP730. However, I am not able to command the scanner from my HP...
Theres a few things you can do, HP normally makes you install a slew of programs with the driver, see if you can find the program called something like "HP Scan" and try to use that to scan things. If that does that work, reinstall the driver.
Hope that helped!
MP730 won't power on, I've checked the power supply everything is fine.
Hey!Its most likely to be the logic(scnt board)The one where the usb port sits!!But it is a expensive spare and the MP730 is an old machine,Best advice.....Buy a new machine!!!Good Luck!!Sorry!!
2helpful
1helpful
How do you install a multi pass mp730 printer
The OS Vista can not make match with my printer Canon MPC190
Try downloading the driver from this link:(i am assuming i got the correct model)
Multipass MP730
Printer Usage
Email canon customer service for that information.
Download to Windows Vista
Hi - You can download the software from the link underlined in blue below:
Multipass MP730
Select Vista from the drop down menu.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
1helpful
Lost install cd
You can download the drivers from Canon's website.
Canon MP730 won't print at all (blank pages).
try to move the blue nozzel over the printing head to the from the right to the left and try, it will work
old marine
old marine
ZJ Limited
ZJ Limited
