Yamaha Waverunner Xl 800 / Xlt 1200 Jet Ski Pwc Cover Logo
A
Anonymous Posted on Jan 26, 2014
Starter relay replace nissan altima - Yamaha Waverunner Xl 800 / Xlt 1200 Jet Ski Pwc Cover
txslim55
Level 3:
  • Yamaha Master 1,104 Answers
  • Posted on Jul 07, 2015
txslim55
Yamaha Master
Level 3:
Answers
1104
Questions
Helped
409663
Points
5454
2005 nissan altima, no crank no start
Try starting it in neutral instead or park...It may be your neutral start switch is bad in the park position. Otherwise, it sounds like a starter relay is not working.
How do I know which one is my starter relay in my 97 Nissan Altima?
Usually there will be a chart on the back of lid for the fuzebox. And it will say what kind of fuze it is.
My 1997 Nissan altima wont crank over
Test battery, and check for loose connections. Check starter fuse & relay. If you don't hear clicking sounds while trying to start the car then most likely it's a bad starter relay. If your getting voltage to the starter but no click then you have bad starter.
1helpful
The starter relay switch where is it i need like a picture of where it is so I can replace it.
I don't believe this has a starter relay. It has a starter solenoid and I believe it is built into the starter. Call advance auto or you local parts dealer and ask them if the solenoid is built into the starter. No relay though. If it is built in you have to purchase new starter.
My 2002 nissan altima will not crank at all, is it the fuel pump ? or some other problem. and the weather is very cold.
Check your starter, it might not functioning.
Start withe the starter relay and then to the starter itself.
Try to short the two terminal on the solenid by using a crew dirver would crank the starter.
Where is the starter relay for a 1993 Nissan
the car had only theft warning relay location on the front right fender check fuse link location on the front left side fender
1helpful
My nissan sentra 95 wont start and its not the starter
it sounds like a starter kill relay was installed on your nissan, if there is a relay in line with the black/yellow or black/blue starter wire under your dash you may need to bypass it, or you might need to reprogram your remote to close the relay when you unlock your doors
3answers
Replacing a starter and starter relay on a 1994 Nissan Pathfinder
Starter relay is located in a "fuse box" these rearly go out. Check your starter to make sure you are getting power to it when you turn your key. if so then worry about the relay or the Starter Solenoid.
3helpful
Replacing a starter for a 1999 Altima
  1. Disconnect battery ground cable.
  2. Disconnect starter wiring from starter.
  3. Remove starter retaining bolts and the starter.
  4. Reverse procedure to install.
the bolts should be on the drivers side.
you will have to crawl underneath the car to do this task
Top Yamaha Boating Experts
neil
Stan Ford
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
