Toro Power Max 724 OE 24 inch 205cc Two Stage Snow Blower Logo
A
Anonymous Posted on Jan 25, 2014
Toro power max 724 - auger lever wont stay engaged when the drive lever is engaged
Joe Stanch
Level 3:
Master:
  • Master 755 Answers
  • Posted on Jan 20, 2015
Joe Stanch
Master
Level 3:
Master:
Answers
755
Questions
0
Helped
152022
Points
1817
Adjust the cable for the auger , easy
I have a Toro 724 snow blower model 38050. It runs great. Everything works and turns. When I engage the drive and or the auger. It kills the engine like when I shut off the key. If I hold the safety...
Sounds like the safety switch is bad or needs resetting. I had a lawn tractor that did that and I disconnected the safety switch. I know you should not do this but I did not want to put more money into this machine. It does work ok without it.
Feb 18, 2018 • Toro Garden
1helpful
Left auger does not engage/spins freely
The shear pin is sheared off. Somewhere along the auger, you'll find a hole drilled all the way through it. The shaft inside also has a hole drilled all the way through it. Compare the two augers - the holes are USUALLY in a straight line with each other (when one is up/down, the other is also up/down).
Get a replacement shear pin (DO NOT use a hardened bolt!) and put it through the holes when the auger holes are lined up with the axle holes.
Vibration when auger is engaged in Toro 726 oe
be sure to check pulleys for a rock or anything else lodged in there
then check rear bearing for alot of play up and down
1helpful
Auger clutch lever disengages even though drive clutch lever is squeezed
On mine (Honda HS55) it turned out to be gummy old grease on the shaft and the lever that are supposed to lock the auger lever down. The spring couldn't overpower the sticky old grease. If nudged or given enough time, it would slowly turn and lock, but not instantaneously, as it should.
10 mm wrench to remove the nut (bottom left) and bolt (under handle) holding on the metal cover.
Once cover was off I could see the locking lever, spring, and the shaft that had the gummy grease on it.
The third photo shows the locking lever as it should be engaged. I had to push it to engage it, due to the spring not being strong enough for the gummy grease on the shaft.
There are flat sides on the shaft, behind the threads for the nut that has already been removed. Use a wrench on those to turn the shaft out. Disassemble. Clean. Oil. Reassemble. Works great now.
Another possibility is that your locking lever or spring are broken.
Auger rattles so bad on idle, toro power max 926 oxe
bad bearings on the ends , this I would have to see but this is prob it or loose bolts on the auger grab with your hand and see if it is loose anywhere , not running of corse
Auger belt on snow blower keeps coming off
if shop just repaired it, go back. Right belt? Tensioned enough?
Toro 826 le snowthrower
I am not sure of the locking mechanics, or what may be worn and requiring replacement.
I recommend that you contact your nearest authorized service center, or you can download operators and service manuals directly from the Agrifab website by clicking on the provided link:
Downloadable Manuals
I trust this information proves useful.
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
