1994 Ford Probe Logo
Posted on Jun 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Speaker wiring im hooking up a stereo to my 1994 ford probe but i cant find the speaker wires.
Jim Goldsmith
Level 3:
  • Ford Master 2,005 Answers
  • Posted on Jun 03, 2009
Jim Goldsmith
Ford Master
Level 3:
Answers
2005
Questions
Helped
736820
Points
6152
The speaker wires are located in a plug connected to the rear of your old radio; purchase a conversion socket kit from an auto parts store to connect your new radio
Anonymous
Level 3:
  • Master 1,305 Answers
Anonymous
Master
Level 3:
Answers
1305
Questions
0
Helped
596346
Points
4327
Here' s the colors to look for in the dash:
1994 Ford Probe Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: Black/Pink
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Light Green/Yellow
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): Blue/Black
Right Front Speaker Negative Wire (-): Blue/Orange
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Green/Yellow
Right Rear Speaker Negative Wire (-): Green/Blue
I got a ford aspire and a pioneer radio how do i hook it up
It is best to buy a connector pigtail for Ford, but you can wire directly using the below color code for the factory wiring. use the color code from the pioneer to match to the factory wires. If you have more questions, please reply.
1994 Ford Aspire Car Audio Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: Blue/Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Red/Black
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Light N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Brown/Black
Left Front Speaker Negative Wire (-): Green/Red
Right Front Speaker Positive Wire (+): Green/Orange
Car Audio Rear Speakers Size: 5 1/4?
Car Audio Rear Speakers Location: Side Shelves
Left Rear Speaker Positive Wire (+): Blue
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Brown/Red
I have a 92 ford probe and im trying to install a
Have you removed the original connector from you original stereo? If you still have the original connector in place you can get a new connector from the Ford dealer that will plug into your existing wiring and into your new deck. Ford connections are unique to Ford and you need to adapt them for this application.
Take the car and deck to the dealer and tell them what you need. Everything just plugs in and your original amp and speakers in the car will work.
Having said that there was an adapter available at Wal Mart of all places that did work. You may want to check there.
If you have removed the original connector then you need a wiring diagram.
1992 Ford Probe Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Red
Radio Switched 12V+ Wire: Blue/White
Radio Ground Wire: Chassis
Radio Illumination Wire: Light Green/Black
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: White
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Left Front Speaker Wire (+): Blue/Orange
Left Front Speaker Wire (-): Blue/Black
Right Front Speaker Wire (+): Blue
Right Front Speaker Wire (-): Blue/Green
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Green/Orange
Left Rear Speaker Wire (-): Green/Red
Right Rear Speaker Wire (+): Green/Blue
Right Rear Speaker Wire (-): Green
The amp is located under the rear passenger side window. You need to remove the plastic side wall to expose it if you need access there. You can trace the wiring if needed.
Under the front bottom edge of the rear seat are clips holding the seat in place. Open the clips and the seat lifts off. You can then get to the amp as needed.
7helpful
Stereo Wiring Color Codes
whoop! there it is!
Car Stereo Amp Trigger Wire: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
window.google_render_ad();
5helpful
1994 FORD EXPLOER XLT RADIO CONNECTORS HAVE BEEN CUT OFF
here is wire color diagram.
1994 Ford Explorer Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Light Blue/Red
Car Stereo Amp Trigger Wire: Blue
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Pink/Light Green
Left Rear Speaker Positive Wire (+): Pink/Light Green
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
4helpful
Need a stereo wiring diagram for 1994 Ford Tempo.
1994 Ford Tempo Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Illumination Wire: N/A
Car Audio Front Speakers Size: 6 1/2′
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
No sound from stereo in 1994 ford probe
did you use a converter plug set for your factory wiring or did you do the siring your self. If you used a factory plug converter then your radio is probably bad, if you did the wiring yourself then check your splices and get a diagram for the wirring before you send the radio back. If you want a easy way to wire the radio in correctly the first time go to cruthfield and buy the converter cable for your radio and vehicle. Its $10 and saves you a lot of time an energy.
tepfy
8helpful
Color code for speaker diagram 94 Ford Explorer xlt
Please rate this info.
Right Rear Speaker Negative Wire (-): Black/White
2helpful
How to hook up my stereo
I hqave taken the time to look this up, please take a few seconds rate the solution, thanks.
1995 Honda Civic Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
22helpful
4answers
1994 ford escort stereo wire colors?
1994 Ford Escort Car Stereo Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Left Front Speaker Positive Wire (+): Violet
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Blue/White
Right Front Speaker Negative Wire (-): White
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Red/Blue
Right Rear Speaker Positive Wire (+): White/Green
Right Rear Speaker Negative Wire (-): Blue
PLEASE RATE THIS INFO AS A FIXYA! IF YOU FIND IT IS WHAT YOU NEED, THANKS ALLOT.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
