A
Anonymous Posted on Jan 25, 2014
Qualia 004 fuse - Sony Office Equipment & Supplies
1 Related Answer
Anonymous
  • Posted on Jan 17, 2013
SOURCE: Sony Qualia 004 doesnt work i cannot turn it on.
Hi the problem is in the board GB, open the projector and find the GB Board an change only one component, the MCZ3001D! The board have two McZ3001D, only change the side position!
1helpful
2answers
Hi there i have a 72" sony qualia sxdr and it shutdown by it self after few seconds, i was wondering if is the lamp ? and where is locate
First, Check the fan. If it's dirty, it won't turn, and will cause the set to shut down. If it still will not turn on, check the "standby" light on the front of the set. If it flashes, it is a different problem, and may well be the bulb.
If you still have a problem with the set, check this site.
http://sites.google.com/site/sonylcdrptvproblems/#TOC-Optical-block-problems-by-TV-model
Sony has had lots of issues with the SXRD series since 2004. There have been a few class action lawsuits and a couple still pending.
Hope this helps
E 004
E 004 is a fusing or heater problem. check heater lamp and thermistor for damage or busted parts and replace them.
1helpful
2answers
How do you remove the panel to replace the bulb on the sony qualia 70" TV
place your head onto the carpet and look up. you'll see two large black thumbscrews near either end of the front panel (just below the screen). turn them counter-clockwise. no force is needed. when they pop loose,
you can gently jimmy the front panel loose. no force is needed
The projector got wet from a leak above the ceiling. is it fixable?
I am assuming the projector no longer works?
does any lights come on, fans, any picture. really need more information
Qualia 005 compatibility with Blue Ray, AND where can I find a stand and a wall mount?
I may be sticking my neck out on this one, but I don't believe there is a way to improve the input resolution. If I'm right, the issue is not related to a firmware upgrade but the hardware design of the board and IC's on them. I have the same issue with a Toshiba 1920 x 1080 resolution TV.
The best you can do is to set the blu-ray to output at 720P which is actually higher resolution than 1080i. Here's why. 1080i is actually two fields of 540 resolution interlaced or put another way one 540 image overlaying a second 540 to make one complete video frame.
Still you make the call as to which one looks best to you
2answers
Sony Qualia and Sony XBR 4 TV
wow. mostly all new set from the last few years have a dual tuners
NTSC and ATSC and that would depend if or which set will get the better signal. Also remember that off air is analog and the sets are now design for digital.
Sony Qualia 46" TV Model # KDX 46Q005
This would mean that your signal is being lost. Instead of snow like from a analog signal you get digital breakup when you get low reception. You need to reposition your antenna or get a better one with a little more power. Nothing wrong with your tv though just not strong enough signal.
Thanks
Josh
4helpful
4answers
Code for universal remote
Abex 172
Admiral 001, 173
Advertura 174
Aiko 016
Akai 002
Alleron 046
Amtron 038
Anam National 003, 038
AOC 006, 005, 004, 007
Audiovox 038
Belcor 004
Bell & Howell 001, 083, 162
Bradford 038
Brokwood 004
Candle 004, 006, 008, 174
Celebrity 002
Citizen 016, 171, 004, 006, 008
038, 105, 174, 177
Colortyme 004, 006
Concerto 004, 006
Contec / Cony 012, 013, 038
Craig 038 v
Crown 038, 171 v
Curtis Mathes 171, 000, 004
006, 015, 105, 162
CXC 038
Daewoo 016, 190, 005
171, 004, 006, 017, 127
Daytron 004, 006, 171
Dimensia 000
Dumont 004, 151
Dynatech 004
Electroband 002
Electrohome 004, 006
002, 003, 019, 022
Emerson 030, 171, 191, 004
038, 046, 006, 012, 023, 024, 025
026, 027, 028, 029 031, 032,
033, 034, 035, 036, 037, 039
041, 042, 043, 044, 047, 123
124, 162, 177, 179
Envision 004, 006
Fisher 048, 049, 051, 162, 180
Fujitsu 046
Funai 038, 046
Futuretec 038
GE 000, 054, 003, 004, 006
022, 052, 055, 087, 164, 165
166, 167, 168, 181
Gibralter 004, 151
Grundy 171, 038, 046
Hallmark 004, 006
Harvard 038
Hitachi 059, 004, 148, 006, 012
013, 060, 061, 135, 136, 137
138, 139, 140, 141, 142, 143
144, 145, 146, 150, 179
IMA 038
Infinity 062
Janeil 174
JBL 062
JCB 002
JC Penny 000, 054, 005, 171
004, 052, 006, 172, 008, 022, 058
063, 064, 072, 087, 105, 181
Jensen 004, 006
JVC 159, 013, 012, 182, 054
060, 065, 066, 067, 123, 157, 158
Kawasho 002, 004, 006
Kenwood 004, 006, 019
Kloss Novabeam 068, 069, 174, 183
KTV 171, 038, 177, 070
LG (Goldstar) 005, 156, 004, 006
172, 012, 019, 056, 057, 058, 155, 171
Loewe 062
Logik 083
Luxman 004, 006
LXI 000, 062, 006, 073
162, 181, 049, 072
Magnavox 062, 004, 006, 130
134, 183, 008, 019, 068, 069
075, 076, 077, 088, 131
132, 133, 219, 235
Majestic 083
Marantz 004, 006, 062
Megatron 006, 059
Memorex 083, 006, 001, 082, 162
MGA 005, 004, 006
079, 082, 019, 022, 051, 080
Midland 054, 151, 171, 172, 181
Minutz 052
Mitsubishi 005, 004, 006
125, 082, 081, 019, 022
051, 079, 080, 135
Montgomery Ward 083
Motorola 003, 173
MTC 005, 004, 105, 006
Multitech 038
NAD 006, 185, 072
NEC 005, 004, 006, 003
Nikko 006, 016
NTC 016
Onwa 038
Optimus 185
Optonica 095, 173
Orion 191, 035
Panasonic 170, 054, 062, 003
Philco 062, 005, 004, 006, 183
008, 012, 019, 003
068, 069, 075, 077
Philips 062, 004, 075, 008, 019
003, 012, 068, 069
076, 086, 087, 088
Pilot 004, 171
Pioneer 004, 006, 090
091, 092, 136, 179, 185
Portland 016, 005, 171, 004, 006
Price Club 105
Prism 054
Proscan 000, 181
Proton 004, 006, 012, 093
Pulsar 151
Pulser 004
Quasar 003, 054, 070
Radio Shack / Realistic 000, 095, 171,
004, 038, 006, 012, 049, 162
RCA 000, 181, 100, 233, 203
212, 098, 005, 003, 004, 006
007, 019, 096, 099, 101, 102, 103
129, 179, 188, 190
Runco 151
Sampo 004, 006, 171, 172
Samsung 171, 004, 005, 105, 006
012, 015, 017, 019, 104, 106, 172
Sansui 191
Sanyo 048, 080, 004
180, 162, 169, 049
Scotch 006
Scott 004, 038, 046
006, 012, 024, 035
Sears 000, 048, 189, 004, 046
006, 013, 019, 049, 051, 066
072, 162, 180, 181
Sharp 173, 095, 171, 004, 006
012, 029, 111, 112, 113, 122
Shogun 004
Signature 001, 083
Simpson 008
Sony 002, 218
Soundesign 004, 038, 046, 006, 008
Squareview 189
SSS 004, 038
Starlite 038
Supre-Macy 174
Supreme 002
Sylvania 062, 004, 006, 088, 076
116, 008, 019, 068, 069
075, 077, 161, 183
Symphonic 038, 189, 033
Tandy 173
Tatung 003
Technics 054
Techwood 004, 006, 054
Teknika 016, 005, 171, 004, 006
008, 012, 013, 038, 046, 076
082, 083, 105, 170
Tera 004, 012, 093
TMK 004, 006
Toshiba 105, 162, 160
161, 049, 072, 118
Totevision 171
Universal 052, 087
Victor 066, 182
Vidtech 004, 005, 006
Viking 174
Wards 000, 062, 095, 005, 004
046, 052, 006, 083, 001, 019
024, 033, 068, 069, 075, 076
087, 088, 119, 120
Yamaha 004, 005, 006, 019
Zenith 051, 083, 004, 152
151, 153, 154, 217
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
