Uniden D1484-4 DECT 4-Handset Cordless Phone Logo
A
Anonymous Posted on Jan 25, 2014
Uniden m/n 1484 displays searching and will not clear
How to I get a security code for my uniden sect 6 D 1484 cordless phone that I bought at a garage sale?
The remote access (security) code is chosen via the handset:
press [menu]
scroll to "Ans. Setup" press [select]
scroll to "Security Code" press [select]
enter the two-digit code of your choice
press [select] ( chirps ) press [END]
Remote *management* of the answering machine is
further described in the owners' manual. To obtain
a replacement manual, you'll need the precise model
number of your phone: this is found on a small sticker
underneath the battery inside the handset. Take this
model number (eg, D1484) to www.manualslib.com
and you can download a free copy of the manual.
Uniden bearcat scanner 800 xlt comes on but screen will not display
Download a schematic from modsdk.com or radio reference.com.Then change the two regulators in the back left corner.Should be a 78mo5 and a 78mo9.THE 7805 is the one usually goes out.
How do i program my 350a scanner
Your BC350C is a factory pre-programmed scanner, and you cannot program is in the standard manner (e.g., directly entering a frequency via the keyboard). You can, however, transfer any displayed frequency from the SCAN or SEARCH mode into your PRIVATE bank. Clear instructions for doing this are in the factory manual that you can download and print, at no cost, here:
http://www.uniden.com/pdf/BC350Com.pdf
Bill B.
Listening in since the 60's
My phone display says searching and i can't make
Go into settings... internet options..Look for mobile connections..Turn it back on
Uniden scanner says pch loc out and will not scan
You didn't mention what the scanner is doing when that display pops up, but here are two possible fixes.
With the scanner powered ON,
- Press HOLD to stop scanning
- Press FUNC
- Press and hold L/O until the scanner beeps twice.
This will clear all locked out channels.
For a COMPLETE reset,
- Turn the scanner power OFF
- Turn the scanner power ON while pressing and holding the 2, 9, and HOLD keys
- After about 3 seconds the display will show CLEAr.
CAUTION: the above will clear/erase all information that you have programmed into the scanner, including frequencies, and reset the scanner to the original factory settings.
I hope this info helps.
2answers
How do i rest a uniden ubc9xlt to have numbers
A full RESET or CLEAR function is not a feature on the BC92XLT, but you don't need it. To reprogram a channel just enter the new frequency (with decimal point) and press the E (Enter) key. In case you need it, here's a link to the owners manual for your scanner:
http://uniden.com/pdf/BC92XLTom.pdf
Bill B.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
