When turning on the camera, the lens comes out like it is supposed to; however, the shutter does not open on its own - we have to use our finger to open the shutter
SOURCE: Kodak c330 Lens Wont Open
Maybe this Link
http://www.fixya.com/support/t102982-e_18_problem
could give you some ideas to look at with you camera . It seems if thing are not lined up just right with the lens. I could see things stalling on these digital cameras.
SOURCE: lens won't come out (Kodak EasyShare C613)
i have the exact same camera
you can hang it up and get ready to buy a new one because its not a do it yourself job and it would cost more to have it fixed than it would to buy another one just like it
SOURCE: Kodak Easyshare camera turns on and off
Hi, here is whats going on, if your M763 is powering on for 2 secs and the lense opens up then go's right back in, there is a 90% chance you got sand in the unit from say the beach ?
here is a test , when you press the power buttion watch the lense you will notice that the bigger part rotates as it comes out, what you want to do is give it a little help Lightly rotate it abit more just at the point where it normaly stops and go's back in, the cam will prob stay on and work like normal.
now the hard part 2 things to try, a can of AIR from walmarts try to blow out and sand thats around the rings, i did this and have fixed about 20 of these's now, on the others you will need to take it apart and clean the gears and mech of the lense housing then put it all back together.
hope this helps
IST tech
Chris
SOURCE: Lens error 10e,1,10- Kodak EasyShare M753
this is an hardware error. I'm sorry but you can't fix it by yourself. You've to contact kodak for a repair.
SOURCE: Kodak EasyShare C653 Camera, cannot connect to my macbook
Try a dig. USB plug,
Try a dif. cable.
Try with a cardreader.
If your cable is faulty it is covered under the same 1 year warranty as the cam.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
