Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
Posted on Jun 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Moultrie I40 will not go to picture mode
I have a moultrie I40 game camera. The power comes on but when I press the mode button to go to picture taking mode it will not go0.
  • Ronald Lockhart May 11, 2010
    does it show setup/time/date screen before you press mode?
Ronald Lockhart
Level 2:
  • Moultrie Expert 296 Answers
  • Posted on Mar 14, 2010
Ronald Lockhart
Moultrie Expert
Level 2:
Answers
296
Questions
0
Helped
123820
Points
644
Are you pressing mode in setup window?
How do you get the m100 to take pictures by motion only?
Search Results
    [PDF]Instructions for M100 GameSpy Digital Camera - TrailCamPro
    www.trailcampro.com/manuals/2012/m-100.pdf
    THANK YOU for your purchase of the M100 GameSpy Digital Camera. Please ... The Mode Button selects the 3 modes of the camera - Camera Setup Photo Review or ...Accepts the Moultrie PowerPanel accessory (sold separately) only. ... Camera operates in Plot Cam mode during the day and Trail Cam Mode during.
    Moultrie Game Spy M-100 IR Mini 6.0 Megapixel Digital ...
    www.walmart.com/ip/Moultrie-Game-Spy-M-100/16386230
    Walmart
    Rating: 4.5 - ‎21 votes
    MOULTRIE Game Spy M-880 Low Glow Infrared Digital Mini Trail Game Camera ' 8 ....You can easily hold this mini IR camera in your palm. ... MFH-DGS-M100 .... Will ittake pictures only on motion detection? ... can get any size you want but don't forgetyou will have a lot of photos to delete. ... A. Will do video clips and stills.
We can't find the disc to download the Moultrie GameSpy i40 camera to view the pictures in the camera
use a usb/mini usb adapter cable...one comes with new Moultrie i-40/i-60 cams, or get one for Blacberry or Sony cellphones...same fit...older d-40 cams use different size.Plug cable between pc and cam;go to"My Computer"...should show a HDD identified as Moultrie. Doulbe click...enjoy pics; no software needed.
The screen has gone blank. It is still taking pictures.The camera is Moultrie game dgs-I40
www.moultriefeeders.com/support for new display with replacement instructions...not hard to replace.
4helpful
2answers
1helpful
2answers
Moultrie I40 infrared not working
The ir gets power thru capacitors and inductors on main board.;check for loose connections, broker leeds; may have to replace ir array or main board to fix.Forget Moultrie having spares; try to buy used on as is from eBay.
6helpful
2answers
Moultrie I40 getting error code 480 and wont go into auto mode
ERROR CODE 000480 ?
If this is correct,it relates to: Camera Mod test failed;(4); and under Memory Test, 8= Comms Error.New batteries(good ones) may fix it...
It' not communicating with memory card..ck it's inserted good..press down until it stays down(press again and it will pop up.
Follow instructions on deleting internal memory before installing SDcard.
Also, make sure cam supports kind of card you're using..at 4gb and larger, they become confusing;i.e., 4/8/16mb...older cams won't support some of these. Also there are HC(high capacity); HD(high definition)don't work in these cams..
I posted this for a fix a few days ago, and it turned out to be brand new bad batteries.
1helpful
2answers
WHEN I TURN ON MY UNIT A MOULTRIE I40 AND HOLD DOWN THE MODE BOTTON TO GET AUTO ON SCREEN THIS IS WHAT SHOW UP ON SCREEN TRG SIC RSND PWO 00040000005000
I had the same problem. After much testing, I realized that the SD card had a problem, so I reformatted it on the computer and that solved the problem. I may replace the card anyway, as they're relatively inexpensive.
2answers
I-40 camera will not go to picture mode and start taking pictures
Have you done the time/date setup? Online manual says it goes auto after 4 minutes, but perhaps the date/time need to be setup first? Online manual here in case you lost your book :)
http://images.ebsco.com/pob/moultrie/catalog/dgs-i40-user-manual-compressed.pdf
be patient, it takes a bit to load
1helpful
My Moultrie I40 seems to be stuck in set up mode. won't advance to Auto. test button brings back error 4800. Tried calling their customer service, no matter what extension i select i just get hung up on.
what does battery % say? twice this prob was solved by using good brand new bats; might try removing bats with cam on; turn cam off; replace bats and power up. Wait until setup screen is on before pressing mode.
Top Moultrie Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
Jerry Naidoo
Paul Bade
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
