SOURCE: Magellan RoadMate 700 GPS unlockmap
Steve, In this case I would replace the Hard drive. But, since you probably don't have spare HDD's lying around.. do you atleast have the Software version? Some CD that came with it hopefully. If you do, then you may be able to stay alive here. Once your system boots to the user screen.. press + and repeat key at the same time.. "secret" menu now. ONLY IF YOU HAVE SOFTWARE TO INSTALL!! Select NAND FLASH FORMAT.. The unit will shut down after formatting. start up your software installer on computer. plug usb in.. and power on unit. This fix isn't %100, but it's the best shot you have. Otherwise you've gotta send it down here to Texas (where magellan repair is) and pay for the new hard drive. OR.. you could call customer service and see what they have to say. you'll probably be transferred to overseas.. --good luck with that -Dan
SOURCE: GPS doesnt turn on with power cord adaptor or 12v lighter socket
if you can verify that the car charger is ok, try plugging it in to your computer using the usb cable. the 1412 should charge with the usb cable. if it still doesnt turn on, try and reset the unit,little pin hole on the side.
SOURCE: My magellan GPS Roadmate 1400 hard reset
there is a little pin hole on the side on the unit. you need a paper clip to reset it
SOURCE: my magellan roadmate 1440 will not turn on? Is
get a new one.. no way to fix unless u get a new battery
SOURCE: Can I charge my magellan roadmate 1340 using the USB?
Should be able to so long as it is set up for it, plug it in and see if the power light comes on, then leave it for an hour, at that time see if you can turn the unit on. You will at this point have your answer to your question. Make sure the computer is on though. (i know, but i didn't put that in one time and i got a nasty message from somebody, so now i put it in.)
Testimonial: "Thanks. Short sweet and to the point!"
