SOURCE: Need Radio code for Vauxhall Vectra
yellow pages most phone unlocking places do car radio unlocking for a fiver
SOURCE: lost radio code for vectra
First make sure that the code has not been noted somewhere
within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be
removed from the dashboard (and if you are lucky, someone may have written the
code on the casing ) .
If not then POST A NEW QUESTION
quoting the radio
MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN
THE METAL CASING
Also quote the MAKE of CAR
note: Unfortunately not all radios can be decoded using the
Serial Number
Otherwise try your Main Dealer ...........or take it into a
Decode Service who will plug in a laptop to read/recode the memory chip
(EEPROM). This takes a few minutes and shouldn`t be too expensive
Testimonial: "Thank you very much for your help, i will try all you have suggested, regards phil"
SOURCE: code for car radio vauxhall vectra radio cdr 2005
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Unfortunately
the majority of SIEMENS/VDO codes (including your CDR2005) will
NOT be available for free (or
cheap) from anywhere on the Internet as
access is required to the original factory database…which is not commercially
available..
Try your
Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are
normally the cheapest option) who will connect it to a laptop to read/recode
the memory chip (EEPROM)
SOURCE: delco no.90 566 821 ,suplier 4660103 mc,gm
I need a code for this cd-player, because I losted and it*s from vauxhall vectra b delco no.90 493 281 ,suplier 4 660 103 mc, GM 90 493 281 cdr 500 >PA 6 - GF 15< Thanks. mail [email protected]
