PANASONIC MICROWAVE NN-S960BC/WC seems to be dead. Nothing shows in display, and nothing functions otherwise. Power is OK. Plugging into a different circuit gives same result. Is there an internal fuse? how do i change the fuse on the microwave; i seem to be having the same problem and i wish to change the fuse before having to buy a new microwave....where do i buy the fuse?
Shop online for all your home improvement needs appliances bathroom decorating ideas kitchen remodeling patio furniture power tools bbq grills carpeting lumber concrete lighting...
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. ... with a different part number (D3V-16G-2C25) but it doesn't look like it's stocked. ... Problem now is that when we open the door, themicrowave comes on by itself! ... I am not sure, when you hooked up the volt meter, did the lights turn on and off ...
i have a nn-h965wfx the light comes on the countdown initiates but nothing comes .....I have a similar full size panasonic inverter microwave NN-L931BF built in ..... After putting it all back together the thing doesn't even power up the display.
Amazon.com, Inc.Ft. Countertop Microwave Oven with Inverter Technology NN-SN661S Stainless at Amazon.com. ... The microwave panini meals even end up with toasted crisp bread. ...But, right now, I find the interior light functionality just fine. .... (1) In this Panasonic, the light doesn't come on when the door is open; it only comes on when ...
Hello
Two options to try:
a) Press the Clock / Timer button 3 times
b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Hi, if it went dead while it was in use, then it sounds like the HV section (magnetron, HV diode, inverter section - if used, etc) has failed, possibly only economic to fix if it is a convection microwave.
From my research, this sounds like a fairly new model. Consult your user's manual to see if this is a user, or common issue. If nothing is descibed then I would seek possible warranty service, or dealer replacement
