To emulate Amiga buttons on your X2 Plus Game Stick Retro Console, you can use an emulator like Amiberry or lr-puae . Here are the steps to emulate Amiga buttons on your X2 Plus Game Stick Retro Console using Amiberry:
Install Amiberry on your X2 Plus Game Stick Retro Console by following the official installation guide .
Download the WHDLoad packages for Amiga games you want to play .
Place the WHDLoad packages in /home/pi/RetroPie/roms/amiga/.
Configure your controller by following the official controller configuration guide .
Launch Amiberry and select the game you want to play .
If you prefer to use lr-puae, you can install it from the optional section of the RetroPie-Setup Script . Once installed, you can place your desired Kickstart ROMs in /home/pi/RetroPie/BIOS/ and use disk and WHDLoad games with this core .
If you turn the Jacuzzi pump on and it just hums and no water flows through the jets then you have a bad pump. You will need to get the brand name of the pump and the model number before you can begin your search to find the proper replacement. Bath Pumps each have their own size. You will want to find the exact brand so you do not have to change any of the plumbing.
There are no reset buttons on Bath Pumps. They do have a thermal overload switch in the motor so it will shut off before it burns up. that is thermal so when it cools down it will let the motor come on again but there is no reset switch on any motor. US Parts Center
Hi Robert Bissett, The amiga drive Chinon F-354 have jumpers, long itme ago I did this. I think you have to set a jumper for the drive there is both normally marked with DS0 one of the drives need to be changed to DS1.
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button. This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight. Be sure to check the connection at the motor too. Good luck
