The detergent draw wont stay shut during a spin cycle
SOURCE: Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
SOURCE: Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
SOURCE: My wash spins SO loudly
hiya
sounds like your drum bearings are in need of replacing.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
SOURCE: Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
