JUMP START SYSTEM Logo
Christopher Valverde Posted on Jan 25, 2014
How do you use the vector start it pro to charge a battery
roy west
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jan 26, 2014
roy west
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
1409
Points
18
Those are made to store power for jumping vehicles. I would boost the vehicle let it run to charge battery
1 Related Answer
Anonymous
  • 152 Answers
  • Posted on Feb 22, 2009
SOURCE: can not figure out how to charge the Vector start
Easy, just insert the "cigarette lighter style" plug from the A/C charger into the "cigarette lighter style" socket on the top of the unit, and then insert the A/C adapter in to a wall socket. It can also be charged in your car with a cord that has double "cigarette lighter style" plugs at ether end, one inserted in the Vector and the other in your cigarette lighter.
Wait, one more - clamp the units cables properly on to your cars battery terminals, then start your car. periodicly checking for full charge.
Hope it helps... Good luck
1helpful
2answers
I have a vector 300 amps that will not charge or hold a charge.This is the first time i needed a jump and did not work!It must be a MANUFACTURER DEFECT.What to do? Your Customer I would like a replac
I know how you feel because I had the same problem with mine until I read about the procedure.
Most of those Jump start chargers unfortunately require that you charge them when you buy it and then maintain the charge at least once a month.
There is usually a light on the charger to indicate that the charger is fully charged.
2answers
The overall verdict is this is a poor quality jump starter which has an unreliable charger and a battery that will die if you don't look after it. However, I found one fair report on Amazon amongst many bad ones:
"The compressor on this unit, like so many others this small, is really only made for pumping up toys or bicycle tires. So don't buy this unit for that purpose. Go to a gas station with quarters and use their air vender.
If, like me, you bought a used unit, you will need to get both the manual and the charger. Do a search on servicenet dewalt to find the owners manual. The manual is a download pdf. Charger model number is 514005-42.
Hope this helps. It's really a neat little device to have around. I especially like the built-in LED flashlight.
You really NEED to read the manual all the way through. The special sealed type battery requires charging at least every 60 days or it WILL go bad quickly."
The Manual is here: http://documents2.dewalt.com/documents/English/Instruction%20Manual/Vector/VEC010BD.pdf
Because I'm an engineer I know I could easily replace the 12v lead-acid battery charger, open the box and replace the battery with another 12v say 200 Amp cranking (short circuit effectively) battery but I would tend to spend a bit more on a gel battery of similar spec 'cos it basically is the only sort that should be used for deep cycle discharge with such a small volume battery. Good luck.
Vector doesn't hold a charge.
How old is it? If it's more that 2 years old the battery needs to be replaced.
4helpful
2answers
I have a Vector HID Spotlight Power on Board SLH100P and I'm trying to recharge it. When you plug in the charger the led lights flash and click really fast. What could be the problem? Thanks for your...
The battery needs replaced. In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. Or, you can order a replacement battery from: www.batterymart.com/p-6v-4_5ah-sealed-lead-acid-battery.html
Vector jump starter displays error F03
http://www.baccusglobal.com/bd/manuals/NEW%20MANUALS%20FOR%20WEB/VEC012POB%20MANUAL.pdf
1helpful
3answers
Everything works but the jumper cables
Most likly the battery is old and will not keep a charge. I just replaced my battery for about $50 a few weeks ago. Go to a story like Battery + for a replacement. It worked for me.
3helpful
Can not figure out how to charge the Vector start it pro
Top Vector Vehicle Parts & Accessories Experts
Sean Wright
Sean Wright
john h
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
