Thanks to those who suggested answers. My user guide had no code for Cello TVs so I tried the search method. Got to 1200 or so presses, by which time I'd lost precise count because the remote did not respond to presses more rapidly than 1/second. Anyway, at about that number of presses, finally the TV turned off. Heh heh. 15 min of wasted time, because the TV would not turn on again using the power button on the remote.Thanks to those who suggested answers. My user guide had no code for Cello TVs so I tried the search method. Got to 1200 or so presses, by which time I'd lost precise count because the remote did not respond to presses more rapidly than 1/second. Anyway, at about that number of presses, finally the TV turned off. Heh heh. 15 min of wasted time, because the TV would not turn on again using the power button on the remote.
You can't post conmments that contain an email address.
Testimonial: "Thanks for suggesting those extensive sites ... a very helpful extension to my own searches. I'll work away at it over the next few days."
2022. Check this code. If you wish to get more, http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its
left side bar, or view it in Timeslide option.
http://www.maplin.co.uk/media/pdfs/A79HQ_manual.pdf
- Manual for ONE-FOR-ALL URC-1625. Replace "MAGIC Button" with the "OK
Button" on your URC-060500R01-11 remote control. This worked for my
TVONICS MDR252 REMOTE URC-60500R01-11 and Logik LCX17LN2 TV using code
0880.
Set up codes for Toshiba TV are: 0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117
0141
Direct Code Entry
Press and hold the SETUP button until the red indicator stays on, then
release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator
blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry,
the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further
programming is required. Note: If some buttons do not operate your device, try
one of the other codes for your brand.
I can help you with your URC-3021 Universal Remote Control issues.
I do not see a listing for Diamond Vision TV/DVD combos in the One For All URC-3021 Code List.
But
don't
give up; many manufacturer's re-use others' control codes. Therefore,
I recommend using the One For All URC-3021 Code
Search feature to find the
compatible codes to control your device.
I hope that helps.
_______________________________________________
One For All URC-3021 Manual One For All URC-3021 Code List One For All URC-3021 Code
Entry One For All URC-3021 Code
Search One For All URC-3021 Reassign
Key
