SOURCE: Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
SOURCE: Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
SOURCE: Sharp -COPIERS - AR-5316 Advanced Digital Imager
Hallow, this is a problem with the exposure lamp on the document glass which is not working or if it is lighting, it is not sensing the white mark on the cover which is above it.
Remedy
Please check if the cover that locks the glass is well screwed or present.
Check if the copy lamp is lighting and replace with a working one.
Check if its cable is not disconnected on its power board located beneath it.
Replace the main board of the machine.
Nb use that sequence to solve your problem and good luck.
