Samson Technology Zoom H4n Handy Recorder Logo
W
Will Callaway Posted on Jan 25, 2014
Just trying to convert a wav to an mp3 on the h4n.a little help? CANNOT get to the encode screen.thanksWill225 772 2356
Trying to get to the ENCODE screen to convert a wav file to an mp3 and CANNOT get to the encode screen. thanks Will 225 772 2356
godzai
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jan 31, 2014
godzai
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
1190
Points
22
Open up the battery door. Make sure that the switch it is not set to "stamina mode". This disables many main menu options
Zoom h4n freezes at please wait why is this?
I have a zoom H4n. Can you include a photo of your screen? What are you trying to do when it freezes?
Sep 16, 2018 • Zoom Music
How do I transfer track data to computer?
Why you have to convert to mp3 ?. Did not the card can be removed and installed on the computer and then copied?
Where you convert the file? BR or computer?
What software you use to convert?
Why a low remain record time on zoom h1 handy recorder when .wav setting in use?
when you record in .wav format, the files ARE better quality, however, they are ALOT larger than a standard .mp3...if you can't tell the 'loss in quality', i would suggest to keep recording as .mp3...but if a .wav is preferred, then i would suggest upgrading the SD card. ..hope this helps.
May 23, 2014 • Music
How to change keys on a song on Zoom H4n handy Recorder
There is a realtek app for sound cards that will do that and karaoke, it comes on many laptops and desktops. Some cmedia cards use this same app with their driver. Search for and install it without the drivers and it works on lots of hardware. Not sure if it will work on that zoom but, I would definitely give it a try. I have used it on several systems including the one I am using at them moment. I have a copy of it but I don't have a link to it, though. It's called realtek HD audio manager, and has tabs that has effects, open tab and on the right top corner has karaoke voice removal and choice of key.
Zoom h4n won't connect as mic via USB
What I figured out - simple. Plug your usb cable all the way in. That's it. Did I guess it? ;)
Why are my exported wav audio recordings so quiet (almost muted) when i replay it on my computer? It is this way when i record in both stereo and mono. When i export it and then play it on my pc through...
Make sure that the file format is the same, first. If so, try converting the format from wav. to a more recent format type, such as mp3, or mp4 if possible. This may help, as the computer may recognize it better depending on the program you are playing them with.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert, Phone Support @ Fixya.com
Apr 29, 2011 • Boss Rc 50
Hello, i am having noise problems when i recording with my zoom h4 in mp3 format, the funny thing is that every thing is ok when i record in wav format, do you have any idea about what could be the...
MP3 is a compressed format so there MAY be some SLIGHT distortion in MP3. It should not be a significant level however. I would contact Zoom and get support from them regarding this problem.
When u export the track down too a wav.form and i convert it too mp3. if i listen too it in headphones i can only hear the vocals in the right earbud.
Well, did you run the vocals through a mixer and send to BOTH channels of the Lexicon Alpha? If you connect the mic to only one channel you will only get one channel UNLESS you process the .wav file and PAN the vocal channel into both channels when outputing to your MP3.
I need help with my Boss Micro BR. I want to convert the song I recorded to MP3, so that I can hear it on my laptop. I connect the recorder with the laptop through U.S.B. and can only get to the files that...
Go to bossbr.net - Plenty of answers there! And yes, you have to master or export the tracks to .mp3 or .wav. These files will be located in the mp3 folder. Boss also makes a free .wav converter located on their website.
Top Samson Technology Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Samson Technology Music Expert? Answer questions, earn points and help others
