BSD On
BSD 9.20 - Transfer Belt Position Monitoring
Description
Belt Home Position too long
Initial Action
NOTE:
If this fault is declared 3 times in succession, the print mode will be disabled. In order to clear this condition, reset NVM location 741-105 to 0.
Check the opening/closing of the Front Cover.
Turn the power OFF then ON.
Procedure
Check that the Transfer Belt is in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Center if required (see REP 9.3).
Perform ADJ 9.13 Belt Edge Learn Cycle.
The Belt Edge Learn Cycle ends abnormally.
Yes No Unanswered
End
Check the reflective mark at the rear of the Transfer belt.
The reflective mark positioned correctly and reflects properly.
Yes No Unanswered
Clean the reflective mark and reposition it properly, if the problem continues, replace the IBT belt ( PL 7.3).
Enter dC330 [042-200 Transfer Belt Home Sensor]. Rotate the belt manually for 1 turn.
The display changes.
Yes No Unanswered
Go to OF 99-1 and troubleshoot the Transfer Belt Home Sensor ( PL 7.5).
Check the operation of the actuator of the Transfer Belt Edge Sensor Assembly.
The actuator moves smoothly.
Yes No Unanswered
Replace the Transfer Belt Edge Sensor Assembly ( PL 7.4).
Select [042-016 IBT Steering Motor (CW) High Current] and [042-017 Steering Motor (CCW) High Current].
The IBT Steering Motor operate.
Yes No Unanswered
Go to OF 99-9 and troubleshoot the IBT Steering Motor ( PL 7.4).
Check the installation position of the IBT Belt Module (the four legs of the IBT Belt Module are placed on the board springs of the Transfer Drawer and the fixing screws (M4: x2) of the IBT Drawer are tightened).
The IBT Belt Module is installed in the proper position.
Yes No Unanswered
Adjust the installation position of the IBT Belt Module.
Set dC131 [741-105 Angle Data Initial Value (A0)] to 0.Install the IBT Belt in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Perform ADJ 9.13 Belt Edge Learn cycle.
Yes No Unanswered
End
Replace the Transfer Belt Home Sensor ( PL 7.5). If the problem continues, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem persists, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem is persistent, replace the IBT Belt Module ( PL 7.1).
042-326 code will be come
