Question about Electrolux EL6988E Oxygen Canister HEPA Vacuum
How do I remove & replace carry handle?
The carry handle part of the vacuum broke and Electrolux sent me a new handle to replace. However, I cant seem to figure out how to remove the OLD one without breaking something else. HELP!
    Top Expert:
  • Electrolux Master
  • 52,781 Answers
Refer this issue directly to Electrolux for guidance in replacing the handele.
Posted on Jan 25, 2014
SOURCE:
After removing six screws, how do I get case apart to repair electric cord
How do i replace the power cord on electrolux nimble - Fixya
www.fixya.com/.../t25091002-replace_power_cord_electrolux_nimble
Sep 11, 2014 - Power cord is frayed next to body, need to replace it. how do i get ....See all Electrolux EL8602A Nimble Upright Bagless Vacuum Questions.
Amazon.com: Customer Reviews: Electrolux Nimble Upright ...
www.amazon.com/...EL8602A/.../B004GUFWBM
Amazon.com, Inc.Electrolux Nimble Upright Bagless Vacuum, EL8602A ... The rotating brush on/off buttons are located right under the soft-touch power button high up at .... Cord is a $30replacement part, which I'm regretting not doing from the get-go, due to ...
Apr 13, 2015 | Electrolux EL8602A Nimble Upright Bagless...
Beater bar on electrolux el8602
Usually you have to replace the belt or if it is burning up belt take beater bar out and check the ends to see if they turn. Sometimes they get thread up in them from carpet and get stuck from turning and then they will burn belt up. Rich
Dec 21, 2014 | Electrolux El8502a Versatility Bagless...
The hand held unit of my ergorapido works, however when in the stick the unit will not work, it seems to fire up then stops
check under neath to see if the bel is connected or it broke if its not sucking im not really sure how to answer that ive never had that happend it can be a wiring issue or switch it sounds like it can be the switch might need replacing the power or the pedal that unlocks it from the stick mode might be pinching somthing that stops it
Dec 05, 2014 | Electrolux EL1022A Ergorapido 2-in-1 Stick...
How do you get the rollers out oy the electrolux nimbke
This is very easy, all you need to do is remove two quarter turn locks on the bottom plate and then you remove the plate and can assess the Electrolux Nimble Brush Roller 16136 1
Aug 23, 2014 | Electrolux EL8602A Nimble Upright Bagless...
How do you access the motor and guts of an Aeruslux or Electrolux Canister Vacuum Cleaner
Hi, I can help. Flip the canister on it's back. Remove all crews. Should pull apart from there. If not check around body to see if it's clipped. You may have to pry the sides apart. That will give you access. Be careful and pay attention to where everything is. Good luck.
Jul 22, 2014 | Electrolux Band Aerus Lux Legacy Canister...
Electrolux nimble troubleshooting
Check with Electrolux for information regarding the parts you need.
Dec 04, 2013 | Air Purifiers
My electrolux Nimbles roller is not working.
A common problem with roller/beaters is hair caught in the bearings on the ends of the roller. The roller is removable and requires regular cleaning or the belt will be destroyed.
Jun 05, 2012 | Electrolux EL8602A Nimble Upright Bagless...
Electrolux EL6988E Oxygen Canister HEPA Vacuum Logo
284 people viewed this question
Top Electrolux Air Purifiers Experts
ray gallant
ray gallant
Tom Chichester
Marvin
Marvin
Are you an Electrolux Air Purifier Expert? Answer questions, earn points and help others
