Al llegar me enconter que servidor ya no arranca, revise la fuente de alimentacion y esta esta trabajando correctamente, al presionar el boton para el arranque me manda estos sonidos, uno largo seguido de 3 mas cortos. ya revise las ram y las intente cambiar de lugar
SOURCE: Necesito realizar el test de una Laptop Inspiron 8600
My spanish is very poco, but I think you want to start a diagnostics test, and need the combination of keys to start?? That would be the Fn + the Power key. Turn the computer off. Press and HOLD the Fn key, then press and RELEASE the power key. Keep the Fn key down until the screen says that you are starting in the "diagnostics" mode. You will then see prompts to ask if you want to conduct a full diagnostics test or a custom one. If you just want to check one or more parts of the system, choose the custom and select what you want to test. Otherwise a full test will cover all system hardware and will take about an hour.
SOURCE: recuperacion de sistema
COMIENCE, FUNCIONE, MSCONFIG, LENGüETA de Boot.ini Las 2 trayectorias del cargador se deben enumerar allí, y la que doesn' el trabajo de t se enumera como DEFECTO. Destaque la trayectoria funcional del cargador, chasque el SISTEMA COMO botón de DEFECTO, entonces AUTORIZACIóN
in English:
START, RUN, MSCONFIG, Boot.ini TAB The 2 boot paths should be listed there, and the one that doesn't work is listed as DEFAULT. Highlight the functional boot path, Click the SET AS DEFAULT Button, then OK
SOURCE: Quitar Password de Bios de Pc Dell Optiplex GX100,
Hope you can read this. if not, GOOGLE...TRANSLATE.
Removing the PSWD jumper is the correct method of clearing the BIOS password. Removing the battery resets the CMOS.
Remove the power from your computer. Remove the battery. Remove the PSWD jumper. Wait!!!!
Keep power off the computer for at least 30 minutes, overnight is better.
Replace the battery. Plug the computer in. Do Not Reconnect the PSWD jumper.
Now reinstall your operating system and drivers. When finished, restart your system. If everything works and you want to redo the BIOS password, shut the computer down. Unplug the power. Remove the battery. WAIT.
Replace the PSWD jumper. Replace the battery. Plug in the power. Restart the computer, hitting "F2" as it starts....to open the BIOS setup page. Reset your password here. Esc to continue, Yes to save.
Good luck
SOURCE: el problema que tengo es
Nused que cuando movi? la impresora que usted instal? atr?s encima de la bandeja de 250 hojas (es requerido para el modelo 3100cn), es posible que puedan haber da?ado la entierra-conexi?n el?ctrica entre la base de impresora y la unidad de 250 hojas de bandeja.
Devuelva la base de impresora de la unidad de bandeja y conjunto aparte. Examine con cuidado el conector en la unidad de bandeja y aseg?rese del corchete que contiene el conector no ha sido doblado ni ha sido deformado. Consiga alguna ayuda e incline la impresora atr?s suficiente distante que usted puede examinar el conector que aparea debajo de la impresora. Si no ayuda a estar disponible, desliza la orilla de la impresora lejos la orilla de una superficie fija s?lo lejos suficiente en ver la conexi?n.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: mi servidor power edge 2600
Hola, efectivamente hay una falla del ventilador, el LED naranja lo confirma, lo mas probable es que sea necesario reemplazarlo.
He encontrado la solución.
1-Instalar Hablemos Inglés en el Vista.
Hay que instalar una máquina virtual (Virtual Box por
ejemplo), con el Windows XP, y crear una carpeta compartida (la que tenga Hablemos Inglés instalado en el Vista). Se ejecuta el programa
desde XP, y se graba una palabra para que inicie el servidor de habla.
2-Se pasa al Vista sin cerrar Hablemos Inglés en el XP.
3-Ejecutamos Hablemos Inglés desde Vista, y empieza a
funcionar.
4-Ya podemos cerrar la maquina virtual con el XP.
Es un poco complicado, pero funciona.
Ojo, si utilizas Hablemos Inglés desde el XP virtual, probablemente el sonido de las
grabaciones no sea bueno, por lo que hay que utilizar la versión que corre en
Vista.
Todo esto es para hacer que se inicie el servidor de habla,
y vista pueda ejecutarlo.
Saludos y suerte.
R@in.
