Question about New Bright 1:14 Scale Radio Control Full Function Hummer H3 Silver - 27 MHz
I have a 19.2v New Bright hummer. The receiver blew a 10 amp fuse. I soldered in a new fuse.The ohms from positive battery terminal to negative terminal is 12.5. Is this high enough resistance to put battery back in an try it or to low and a system short an will blow my 10 amp fuse again?If there is a short what could it be? what do i need to look at to fix it?
    Top Expert:
  • New Bright Master
  • 53,745 Answers
There is no resistance in a fuse
it is designed to blow when a short circuit happens after the fuse to protect the circuit
fix the problem first
Posted on Aug 23, 2017
SOURCE:
  • 49 Answers
SOURCE: need a replacement part for 1:10 New Bright H3
STU DO YOU HAVE THE DIMENSION OF THE PART IF YOUR NEW BRIGHT TOY 4X4 DO YOU HACE THE ONE PICTURE OF THE PART YOU ARE SEARCHING TO SEE IF I HAVE ONE!
Posted on Jun 17, 2009
SOURCE: new bright 19.2v nicd battery problem
I have purchased 2 remote controlled toy cars from Costco over the years. These New Bright batteris and charges last only a few charges, and then they go bad. I am disappointed. I will go to Walmart and buy a new battery and see if it works better, if not, i will return to Walmart.
Posted on Dec 01, 2009
SOURCE: My New Bright Holiday Express train set is 10
Make sure your track is clean. take a green scrub pad and rub the track to clean off any tarnish
Posted on Dec 28, 2009
mcdevito75
  • 1970 Answers
SOURCE: Where can i get a new battery/charger 9.6v for my
mcdevito75 here, You should be able to contact New Bright on line or with the paper work that came with the Land Rover.
Posted on Jul 05, 2010
Testimonial: "very helpful thanks"
espressonist
  • 1711 Answers
SOURCE: need entire underframe with wheels
If you take the look at the price in the link
http://www.buzzillions.com/reviews/new-bright-radio-control-hummer-h2-1-6-scale-black-reviews
then you will realise why it does not worth to someone sell only the parts you need since you can buy the whole unit at this prices. So you should think to buy a whole unit and if you love the one you already have you can transfer all the parts you need and have also some spares.
Posted on Aug 06, 2011
Bridging two12" subs and one 15" sub to my Rockford fosgate T 1500bd amp
assuming all 3 subs are 3-4 ohms, running all 3 in parallel (the 3 positive leads all attach to the amp positive terminal, and all 3 speaker negative leads connect to the amp negative terminal) will bring you at or above 1 ohm, which the amp is capable of handling. With 1500 watts, you will want to use 8 gague power leads for the amp, 12 gague speaker cables, and an inline 120 amp fuse between the amp and the battery, within 1 foot of the battery.
Jan 11, 2017 | Rockford Fosgate Car Audio & Video
Diagnosis for battery terminal wrongly fitted
Do you know what make, model, year of vehicle it is? Was it a new/fully charged battery? If so then probably blew a few main fuses, ECU, alternator and other electricals.
Sep 15, 2015 | Cars & Trucks
Battery fuse blows when i hook up new battery
With battery disconnected, take a meter reading [resistance / ohms] across the battery leads. It sounds like you have close to a short circuit in your primary charging/supply circuit. 0.6 ohm will take out a 20 amp fuse. Ohms law I = V/R. Quite a few other factors to take into account but you'll have to find what's causing the low resistance.
Nov 30, 2013 | 2005 Harley Davidson FLHRS - FLHRSI Road...
Speakers don't work quite right
Check first to make sure impedance marked on speakers is same as original---two sets of positive and negative terminals suggests original ones were dual element speakers----
If for example original were marked 8 ohm and you put 16 or 32 ohm speakers in----volume will be greatly diminished and even distorted.
This is only a suggestion as I do not know what original speakers were or what new ones are----but the key is originals had two sets each of connections.
May 18, 2012 | 2002 Oldsmobile Alero
I changed the battery and negative treminal for my 1995 ford escort and as soon as I hooked up the battery it blew the 100 amp main fuse under the hood. I replaced the 100 amp fuse and hooked the battery...
At a guess, I'd say that you have got the new battery in back to front. This means that you are hooking the earth wires to the Positive side of the battery.
Mar 24, 2011 | 1995 Ford Escort
I bought both of my sons a remote control car one is a buggy, the other a hummer. one controller controlls both cars so they cant use them at the same time. is there a way to fix that?
You can change the crystals over in the car & transformer,problem is that they may be soldered into position & would need to be unoldered & new ones soldered in. Can get them of of ebay pretty cheap. Should say what frequancy car is on underneath & on box. Some controllers have a switch & can choose out of 3 frequncies.Hope this helps on deciding to go further.
Aug 02, 2010 | New Bright 1 10 RadioControlled Land Rover
How to run wires is series fof 3 subs
If they are single voice coil speakers (1 positive and 1 negative terminal on each speaker) then connect from amps' Positive output terminal to spkr. 1 positive terminal, THEN spkr. 1 neg. terminal to spkr. 2 positive terminal, THEN spkr. 2 negative terminal to spkr. 3 positive terminal, THEN spkr. 3 negative terminal to amps' negative output terminal.
That is 3 speakers wired in series. if each spkr is 2ohms, then you will have a total 6 ohm load. If 4 ohm spkrs., then a total 12 ohm load, if 8 ohm spkr., then a total 24 ohm load.
Be careful because amps do not like these odd ohm load totals. You might get away with a 6 ohm total load. Depends on the amp.
Mar 27, 2010 | Jl Audio 10W6v2 Car Subwoofer
New Bright 1:14 Scale Radio Control Full Function Hummer H3 Silver - 27 MHz Logo
47 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
Jonah Oneal
gerry bissi
Are you a New Bright Toy Expert? Answer questions, earn points and help others
