1 - out of account
2 - Clean all device
3 - Scan Anti Virus
4 - promising device driver
5 - open a new browser site
Testimonial: "Thank u so much I'll try that... I have now only one app that is not installing correctly when loading... I got 2 apps working rite by erasing my gmail account from settings but it still won't allow me to use apps... still says they r not responding...."
SOURCE: my apps libaray on my
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase
Everything"
The following will occur:
• The screen will display COBY
• The screen will display Android
• The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target.
Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home".
The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until:
1- You have configured your Wi-Fi
2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
