SOURCE: view mode incorrect after connecting to pc
hi my name is mark, i own an aquos, the side bar are normal. not all programming is broadcast in wide screen. if you watch during primetime you will see the bars come and go depending on if the program was taped in 16:9 or 4:3 format. you will see it on commericals also. thanks for your question.
SOURCE: I can't get my view mode to change. It is on
If you are connected to a cable box or a satellite receiver make sure its resolution is set to 720p then look on the remote that came with it for the hd zoom # button. You may have a format or aspect button on that remote to change the picture size
When the resolution on the connected device is wrong this can happen.
SOURCE: I do not have a full screen with most channels
most channel are broadcast in 16:9 format. you can stretch the picture somewhat but it wouldnt look right on fullscreen anyway.
SOURCE: We have a 52" Aquos
Go into the user menu and set the default to full. If this does not correct your issue, then take it to a service center. You are still covered under Warranty.
