Kitchen Appliances - Others Logo
A
Anonymous Posted on Jan 24, 2014
Capresso 275 kettle lid broken
Is it possible to buy a new lid and replace the old one? It looks like there are two screw that hold the entire lid assembly in place. Thanks, John
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Dec 07, 2007
SOURCE: Broken DVD player
it is not possible but what u can do is find another same model(which does not work from used up product market ) writer and open it take out the try watch carefully how it is fixed to the writer,now open all the screws of your writer carefully,and replace the one which you have bought from used up items.fit all the screws back and check if it works. if it does not then i am sorry to say you will have to buy a new one.But ya u cld do 1 thing check if the warranty is still there if yes then quickly replace it.
hope this will solve ur prob. plz rate me.
Anonymous
  • 105 Answers
  • Posted on Mar 23, 2008
SOURCE: Broken Touchpad ZIF Connector
Best bet is to obtain a faulty motherboard and use the clip from that - they are often sold very cheaply declared as faulty on ebay.
Please rate my assistance I hope it is helpful.
Anonymous
  • 125 Answers
  • Posted on Feb 26, 2009
SOURCE: Can't get motor and impeller assembly off pump
The impeller unthreads counter clockwise off the shaft of the motor. on the back of the motor under a plug or the plastic cap there is the shaft of the motor with a slot for a standard screwdriver. put the biggest screwdriver you can find in there and turn on the impeller as hard as you can. After some years the impeller can get rusted onto the threads of the shaft and you will need to break it to get it off. (sometimes they just don't come off)
Anonymous
  • 18 Answers
  • Posted on Mar 01, 2009
SOURCE: Where can I find a replacement lid for Cuisinart Kettle CJK-17BC?
You need to talk to Cuisinart (follow this link to their contact us page http://www.cuisinart.co.uk/contactus.asp?menuId=20)
There is no harm in asking. I have had replacement cooker nobs, bin lids allsorts by just being honest with message and asking nicely.
But if all else fails EBAY =P
Anonymous
  • 382 Answers
  • Posted on Mar 29, 2009
SOURCE: Need to replace a headlight assembly for a 2006 Subaru Outback.
No, you just remove the radiator grill and the side marker light and the headlight housing bolts and it comes out. Not a real hard job and is Real straight forward. Good luck and have a good day.
My take care of works but it leaks at the bottom how do I fix that
If your electric tea kettle is leaking water from the bottom, it is likely that the seal or gasket between the heating element and the kettle body is damaged or worn out. Here are some steps you can take to fix the issue:
  1. Unplug the kettle and let it cool down completely before attempting any repairs.
  2. Check the bottom of the kettle for any visible cracks, holes, or damage. If you find any, you may need to replace the entire kettle.
  3. If the bottom of the kettle looks fine, remove the base of the kettle by unscrewing the screws or pressing the release button (depending on the model). This will expose the heating element and the gasket.
  4. Inspect the gasket for any signs of wear or damage. If it looks worn or torn, you will need to replace it with a new gasket. You can find replacement gaskets at the manufacturer's website or an appliance parts store.
  5. Carefully remove the old gasket and clean any residue or debris from the gasket groove.
  6. Install the new gasket in the groove, making sure it is properly seated and not twisted or pinched.
  7. Reattach the base of the kettle and tighten the screws or press the release button to secure it in place.
  8. Test the kettle to ensure that it no longer leaks.
If you are uncomfortable attempting these repairs yourself, it is recommended to contact the manufacturer's customer service or a professional appliance repair technician to assist you.
2answers
I need a replacement lid for my Bella kettle
Give a fast search on Google for: "Replacement lid kettle" and check the results, also measure the circumference of the needed lid before buy a new lid.
Where can I find a replacement filter spout?
About 683,000 results (0.79 seconds) Search Results
    Buy Kettle Spare Parts ' Calcium filters, Lids and More ...
    www.espares.co.uk/browse/at1102/kettles/small-appliances
    Buy spares for your kettle; kettle filters, kettle lids, kettle descalers and more. We carry parts for all home and garden appliances. ... Find Kettle Spares. Black & Decker. Bosch. Braun. Breville. Brita ... Kettle Spout Filter. Genuine spare part for ...
24helpful
2answers
Melitta MEK17W Electric Kettle: The little filter that fits into the spout disinte...
Call 1-800-233-9054 and ask Salton/Toastmaster for part number 31036 for the MEK17W kettle. You may as well buy 2.
When this scale filter in the spout of a Melitta MEK17W or Toastmaster TEK17W (identical kettles) gets torn the kettle does not hold in enough steam to trigger the auto off switch. Same thing happens if you do not fully close the kettle lid. With a new and spare scale filter you will get way more life out of this inexpensive and handy kettle.
If you still have the old original filter, here is an inexpensive and permanent repair option using stainless mesh:
www.fixya.com/answer/answerpageslideview.aspx?thid=10641367&ctg=163&lst=1#answer-section
Plastic catch broken DeLonghi KBX1510
try supper glue??? but dont hold your breth that this will work,,, it realy dont like hot wet places! i know this from first hand experience,,,
as its holding up my left lung!!!!!! and im not kidding you there?
2helpful
2answers
Need plastic handle on Rival Crockpot lid.
easy fix go down to your hardware store and buy a big wooden knob (like you would put on a cabnet to open it) it will even come with its own screw for .99 ! . you will have to snap off with a plyers and a screwdriver whats left of the old knob from the lid . but this fix works great and looks good too !
1helpful
Top Jura Capresso Kitchen Appliances - Others Experts
john h
Are you a Jura Capresso Kitchen Appliances - Other Expert? Answer questions, earn points and help others
