My laptop won't turn on!
Always check power supply first. Ensure green/orange charging light appears in the LED bank near the screen bottom when adapter is plugged in. If NOT then charger or battery (or motherboard) is faulty.
A dead battery shouldn't cause a shutdown, so the charger is the first suspect. The yellow power socket can become 'rusty' in some cases so inspect this also. If the contacts inside aren't clean & shiny then try some WD40 after scraping gently with a 1 or 2mm flatblade screwdriver (with the battery OUT). If not even a P.O.S.T. (Power On Self Test - IBM logo)
appears with the CDROM and Hard Drive removed, Try cleaning the memory and swapping its position on the back of the unit. Good Luck.
I have had success in the past by unplugging the laptop from the wall power, taking out the battery, then hold the power button for 45 seconds. After that put the battery back in, plug into the wall, and turn on.
SOURCE: Always shutdown my IBM ThinkPad A21m 2628 PC Notebook
It must be a processor overheating problem, check the vents are not restricted and if the fan is always on or never comes on because of a faulty temp setting then theres a overheating problem and the processor will shut down before any damage.
SOURCE: unlock ibm thinkpad
IF it is a BIOS password ,Try taking out the battery and shorting the BIOS terminals then reinstallign the battery or leave it out long enought for the capasitors and memory chips to loose their charge. Reinstall the battery and then memory of the pasword wil be no more. BIOS Brainwashing.
SOURCE: my laptop ( IBM thinkpad x31) won't turn on
GO 2 CONTROLL PANNEL .DEVICE MANERGER .MICE AND OTHER POINTING DEVICES ,RGT CLICK PROPERTIES CHECK C IF THE DRIVERS WORKING ? HAVE FUN !!!!!!!!!!!!
SOURCE: ibm t22 thinkpad laptop error 0175 crc1
Ok hm...
Sounds expensive, I'm afraid!
Here is IBM's explanation of the error codes.
What your machine is telling you is that a chip on your Motherboard is faulty and the only way to repair it is a new system board.
It is probably worth finding out how much IBM would charge you to repair it but I very much doubt you'd get much change from £500.
SOURCE: IBM THINKPAD AUDIO DRIVER
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model laptop,
Use this link :-
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
